Recommend electrician for Tucson charging installation
Discussion in 'Mountain/Southwest' started by dweeks, Sep 3, 2014.
  1. dweeks
    dweeks Member
    Flagstaff, AZ
    I'm close to pulling the trigger on a new Model S, but I have concerns about getting a charging station installed. My Tucson house is older (built 1969, and the primary breaker box is a looong way (150+ ft) from the garage. I don't know the rated service capacity of the breaker box. I'd prefer a HPWC, but will settle for a NEMA 14-50.
    I'm not going to do the work myself.
    Can anyone recommend a good electrician for this kind of work, preferably one who has done a HPWC installation?
  2. araxara
    araxara S-P85#3,218 X-LR M3AWD
    Tucson, AZ
    #2 araxara, Sep 3, 2014
    I have used Brian Winkle from Winkle Electric for many projects, ranging from complete home rewiring to installing my sub-panel in my garage to power the HPWC. I installed the HPWC myself, however, because at the time Tesla was behind in shipping the HPWC. Brian installed the 125A sub-panel and various outlets, including a NEMA 10-50 that I used temporarily to charge my Tesla until the HPWC arrived. He did go over the specs of the HPWC and made sure it would work out. He basically charged labor and parts which amounted to about $600 total which including running a 30ft conductor to the garage and installing the sub-panel. He is a licensed electrician. His contact information is
    Brian Winkle
    Winkle Electric
    2610 E Manchester St.
    Tucson AZ 85716-5320
    (520) 795-1001
    Installed sub-panel with HPWC (as you can see I didn't need to do much to install it)
  3. dweeks
    dweeks Member
    Flagstaff, AZ
    FYI,
    As recommended by araxara, I used Brian Winkle for my HPWC installation.
    As it turned out, the length of the run was not an issue, as I had a breaker box right on the other side of the garage wall.
    While it was his first one, he came prepared, having already read the installation docs. He and an assistant had it installed in an hour and a half or so from start to finish. The quality of the work was superior. The cost was $540 for parts and labor.
  4. viper1619
    viper1619 Member
    Tucson
    I used Brian Winkle in Tucson as well. Efficient, effective and knowledgeable... thanks for the referral to him @araxara and @dweeks ... Brian got me squared away incredibly quickly as well.
    See you guys on the road! (or at our lonely Supercharger)
