Recommendation for Commercial Chargers
Discussion in 'North America' started by JasonL, Jul 9, 2014.
  1. JasonL
    JasonL New Member
    About to be held in contempt in an AZ courtroom
    The building in which my office is located is going through some renovations, and an EV charger may be in the cards. The building is relatively new, and there is plenty of power that is readily accessible around the building.
    Management has asked that I give input on available commercial chargers. Any suggestions or would be greatly appreciated. Links would be even more appreciated.
    The charger would be located outdoors, possibly in a covered location. Given that I am in Arizona, exposure to moisture is not a huge issue, but exposure to heat is certainly a factor to consider. Thanks in advance.
  2. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    You want a high amp level 2 charging station(defined as 40A or greater). I suggest Clipper Creek CS-100 which has 80A output:
    High Power Category | ClipperCreek Vehicle Charging Station
    The 30A stations you commonly see that were mostly paid for by government grants a few years ago are practically obsolete and shouldn't be used for new installs.
  3. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    If you will be charging for people to plug in, then the only real reliable way to go is getting a Chargepoint (Electric Vehicle Charging By ChargePoint) station. If it will be free Charging, for starters, contact Tesla, They may provide a free or discounted HPWC.
  4. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Check our ClipperCreek.
  5. captain_zap
    captain_zap Electron tamer
    Redmond, WA
    I second the Clipper Creek CS-100. Full 80A capable output, universal compatibility with J-1772. We installed two at work and they are great. We received discounts from the state for the labor and installation costs as well.
  6. GuyHall
    GuyHall Member
    Granite Bay, CA
    I third the ClipperCreek suggestion. They have been in this business a long time and have a strong reputations on quality and competitive products.
    Guy
  7. djp
    djp Roadster 2.0 VIN939
    Toronto, Canada
    Agreed, Clipper Creek CS100 is the unit to install. The 30A stations from other manufacturers are already obsolete, and the Tesla HPWC only works with the Model S, not other EVs.
    You might be able to get a discounted CS100 from Sun Country Highway, who has been installing high amp L2 stations across Canada and the US.
    Canadas Leader in Electric Vehicle Products | Sun Country Highway
  8. eMileage
    eMileage Member
    Toronto
    I work for Sun Country Highway. So of course I believe that we offer the best solutions at the best prices. :smile:
    Feel free to contact me if you require any information on our product portfolio and latest promotions. Thanks.
    Cheers,
    Emile.
  9. TexasEV
    Austin, TX
    I disagree on both points. The Clipper Creek CS-60 has 48A output and an optional keypad to enable charging for charging. There is no reason to think it's less reliable than a ChargePoint. Anyway ChargePoints are overpriced and underpowered. The CS-100 discussed above unfortunately does not have the keypad option available but it's the best for free charging.
    The Tesla HPWC destination charging program really isn't appropriate here. He's talking about an office building, not a long-distance driving destination. Office building charging will be for workplace commuting and needs to be able to charge Leaf, i3, etc, in addition to Tesla so it needs a J1772.
  10. rcc
    rcc Model S 85KW, VIN #2236
    San Jose, CA
    Uptime and software matters too.
    Chargepoint chargers can be fixed in a 30 seconds by a high school graduate because the innards are one massive replaceable unit.
    Also think about whether the business needs to track who uses the chargers, may want to charge at any point in the future and whether they want to do their maintenance or let a Chargepoint/Blink/whoever do it.
    When I took part in an eval about a year or so ago, Chargepoint looked way better than anyone because their software was more feature-rich and mature and their chargers looked like they were designed for fast, easy maintenance.
  11. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Look also at Eaton which has 70 amps PLUS credit card processing, and/or key fob access which the others do not have.
