Glamisduner
I think that's for 19's not sure on 20'sDoor jam says 42 psi for me.
Is it different for each M.3?
I just wanted to post a quick update after I rotated at 10,000 miles.
I lowered to 35 PSI with only 2000 miles on the odometer, and then rotated them at 5,000 and today at 10,000. I recorded a full 7/32 tread depth at 5,000 all around, in the exact same today at 10,000. The tread wear looks perfect, wear measurements are consistent across all four tires, and I’m extremely happy with how the car behaves at 35 PSI.
I highly recommend you guys give this a try.
Any difference in your wh/mi?
like you say, very different systems.A totally other vehicle , a bicycle, they discovered that at a sertain point , higher pressure did not give lesser energy to use per mile.
Known in this field is Jan Heine, who did much reasearch on pressure for bicycles. There it has to do with the human body wich gives vibrations and so the lesser energy needed by lesser deflection of tire, is at a sertain point lost again by the vibrations, even on a flat road like highway also is.
This is my explanation of the story I read about it, did not understand the principle totally.
On a less flat road ( stones ) the balance even shifted to the lower pressures that gave less energy use then higher pressure , in sand ( but I dont think there are Tesla's that do offroad driving) verry low pressure is better for " fuel saving".
But research could show , that the 42 psi for Tesla, needs yust as much energy a mile as 35 psi , even if a machine drives the vehicle.
It's kind of an interesting topic, but I can't find much information on it. There's a lot of information about underinflated tires, but it's mostly anecdotal and testimony from "experts" talking about proper inflation. I can't find any kind of technical analysis on the efficiency difference.
Further muddying the water is how Tesla's recommended pressure is substantially higher than industry-standard specs require for a car is heavy as the Model 3. The Lexus GS uses the exact same tire size, and recommends 33 psi for a car that weighs nearly the same.
But in the end, it's all academic for me. With the off-peak rate of 7.3 cents per kilowatt hour, I don't really care that much. I keep my Aero hubcaps on because there is no practical reason not to, but I really like the improved ride and handling at 35 psi. And so far comparing with anecdotes online, my tire life will be among the best. And I don't drive conservatively.
interesting, but I suppose it makes sense. Your car is about 400 pounds heavier than mine, so I can see more pressure being helpful.The very high PSI on bicycles is very much for lower rolling resistance, to minimize contact as your weight presses down on a very tiny tire patch.
However I’ve found 35 PSI to -hurt- handling for the stock tires. They start going dead, noticeable turn-in delay around 37 PSI. So should keep 39-40. Wear evenness also about as good as it gets at 40-ish.
Mine actually bled down to 32–33 before I aired them up yesterday, and I noticed no negative handling characteristics at all. Definitely less jittery than when they were at 45.
