Recommended tires M3 Long Range, RWD
Discussion in 'Model 3: Driving Dynamics' started by 2017ModS, Mar 1, 2019.
Tags:
  1. 2017ModS
    2017ModS Member
    San Diego
    Hi, our M3 LR RWD has 25K miles and tires are wearing out. Can anyone recommend all season (non-winter,etc) tires for general commuting purposes in SoCal? We have the standard 18" wheels. The OEM tires at Michelin Primacy MXM4 235/4R18. I'm not particularly overwhelmed by these tires and the cost is much higher than others. Would be nice to get set of tires with warranty as well. I've look at the Pirelli Cinturato P7 but those are not 98H rated, only 94H.
    Thanks!
  2. eastpointvet
    eastpointvet Member
    Atlanta
    I have the same question. Im at about the same mileage and had my tires replaced but if this set wears out that quickly i will definitely want something else.
  3. TeeEmCee
    TeeEmCee Member
    Null
    The original tires are 235 / 45 R18. I plan to run all season tires in the winter, on the OEM wheels, and I will likely go to 245 / 45 R18 for the next set. The 235s look stretched, which is not to my taste, and they leave the rims exposed such that curbing them is guaranteed. 245s should look and protect the rim better, have a bit more grip and, at least at the tire rack, they are cheaper and there are a lot more of them to choose from ( 4 times more choice).
    From past experience, I’d probably get the Michelin Pilot Sport A/S on the sportier end or the Continental DWS for a more refined/comfortable ride (softer sidewall = sloppy cornering though). I had the Cinturato P7 and thought they were OK but not special at all. They also got horribly noisy as they wore down. I’m running the P Zero A/S Plus on my SUVs and it’s a very good choice for a year-round tire. Its weakest characteristic is the less than stellar wet grip (get the DWS for that), but that’s not critical in SoCal.
    • Informative x 2
  4. kwest2
    kwest2 Member
    Boston, MA
    I live in Boston and have always found the Continental DWS09 to be a great all-round tire for all season.
  5. ap105
    ap105 Member
    Kansas City
    I'll 2nd.. I had these for my Toyota Avalon before the Model 3. It made the Avalon feel "new" / could tell the difference. - def gonna try them out whenever I need to get new tires.
  6. Knightshade
    Knightshade Well-Known Member
    NC
    Why would you want an all-season in SoCal?
    All-seasons suck- in all seasons.
    Above 40 degrees they're inferior to summer tires, and below freezing they're inferior to winter tires.
    San Diego average low temps are 49-50 in the dead of winter.
    Get Michelin Pilot Sport 4S tires, the best street summer performance tire on the market, and call it a day
  7. eastpointvet
    eastpointvet Member
    Atlanta
    And what size would you get if you on the aero wheels
  8. Probllama
    Probllama Member
    Colorado
    Your range will be reduced with those tires though, stickier rubber means more rolling resistance. Plus summer tires also tend to be louder than all-seasons if noise is a concern for OP...
  9. Knightshade
    NC
    So would your braking distance in an emergency stop- by a lot. Which is a lot more important to me than range (and I'd hope to most people)
    That's a hugely YMMV situation, I can think of plenty of summers that rate better than all seasons for noise, and vice versa.... for example Michelins own A/S 3+ is often considered the 'best' all season for performance, vaguely approaching the summer king PS4S in that regard, the one knock on the all season being that it's louder.
    Given we know the model 3 isn't traction limited on acceleration probably stick with 235/45-18s
  10. David L
    David L Member
    San Diego, CA
    The 45k mile warranty is valid on the Michelin tires that came with the car, so assuming you meet the requirements (regular rotation, even wear, etc.), the cost of replacements may be less than you think. I don't believe the replacement set, however, would be eligible for the mileage warranty.
  11. jsmay311
    jsmay311 Member
    Chicago suburbs
    Huh? :confused:
  12. davedavedave
    davedavedave Member
    NoVA
    Could be that OP takes road trips to where they're needed. I'd rather take the bus than drive a single snowy mile with summer tires.
  13. Daniel in SD
    Daniel in SD Active Member
    San Diego
    I also vote for PS4S. Hardly any noisier than the MXM4's and way stickier in both dry and wet conditions. If you need to go to the snow then it sounds like the Crossclimate+ have decent all around performance. If you want an efficient, probably unsafe tire then Ecopias are the way to go.
  14. miimura
    miimura Active Member
    Los Altos, CA
    If you are disappointed that they are wearing out at 25k miles, then maybe you want something with a higher tread life rating.
    The Continental ExtremeContact DWS 06 has a 560 treadlife while the factory tires are 500. The DWS is not Eco rated, so your range may suffer slightly. DWS is about $100 cheaper per tire as well.
    Tire Rack - Continental ExtremeContact DWS 06 Size: 235/45ZR18
  15. Glamisduner
    Glamisduner Active Member
    Escondido, CA
    If I wanted AS I think Michelin Pilot Sport A/S is what I would get too, for a little upgrade. I think the MXM4's are pretty good too though, if you want to keep the acoustic foam.
    Does having 2 sets of wheels void your warranty? Trying to figure out what I'm going to do with my stock wheels and tires. Just did the first rotation at 6k miles the rear's had less tread than the fronts.
  16. Randy Spencer
    Randy Spencer Active Member
    Alameda, CA
    Seems I saw a bunch of Model S vehicles with staggard wheels, yet I have not heard ANYONE putting them on their Model 3. Some 10" wide wheels should fit on the back, and I can keep my Aero rims for Snow tires. Am I the only one who wants to treat my 3 as a cheap S that doesn't overheat when racing?
    -Randy
  17. OCR1
    OCR1 Active Member
    Southern California
    Has anyone got a quote on the cost to get a replacement set of the OEM Michelin tires? Do you have to buy them from Tesla or do the tire stores sell them?
    It would be helpful if we eventually see some data on how alternate tires may affect range, noise, grip, etc. At the moment there isn’t much data out there, presumably because the car hasn’t been out long enough for that many people to need replacements.
  18. Randy Spencer
    Alameda, CA
    Not sure if you can even get them at Tesla anymore. Especially disappointed that there is no option anymore for the 18" or 19" non-Winter tires
    Screen Shot 2019-05-12 at 8.33.18 PM.png Screen Shot 2019-05-12 at 8.32.48 PM.png
    Screen Shot 2019-05-12 at 8.33.05 PM.png Screen Shot 2019-05-12 at 8.33.30 PM.png
    All options sold out
    -Randy
  19. smjbh5
    smjbh5 Member
    SF Bay Area
    I have the 19s on my rwd, and the orginal continentals are wearing out fast. I have 10k miles and I probably have another 5k left on them. Whats a good replacement for those? The pilots?
  20. ForeverFree
    ForeverFree Supporting Member
    Sherman Oaks, CA
    Mountains. Snow. Very close. Very deep.
