Reduced power output on Model S P85.
Hi Peeps,
My P85, prior to the last few updates used to put out between 416bhp and 425bhp. 0-60mph was also just over 4 seconds. It now takes far longer to supercharge (2 hours from 2% to 95%), the peak power is only hitting 396bhp and the 0-60mph is 4.4 seconds. Has anyone else noticed this on their P85?
I am using ScanMyTesla to log the 0-60mph and other power characteristics. I tried an earlier version of the software, but still get the same results, so I know it isn't buggy code.
The current motor has only done 15,000 miles, after it was replaced last summer.
The battery is 95% charged and over 35C, so there is no power limiting bar showing on the instrument cluster, which is how I always test it.
Thanks
what firmware?
sounds that same as what everyone else is seeing. SC charging never is as fast as what the estimate says now either from what I see.
new firmware versions cap power input/output at low temperature a lot more. Charging seems to need 110-114F battery for a decent close to expected rate. output is way limited at lower temps to IMO
Reactions: Droschke
sorka
9,866
8,041
Merced, CA
FYI, Tesla isn't the only one doing this. Check your phones folks.
Example? And when I say example, I mean where the the manufacturer locks out battery capacity. I don't mean where the manufacturer slows down your phone when your battery goes bad for real. Not even in the same realm of comparison.
sorka
9,866
8,041
Merced, CA
Hi Peeps,
Thanks
Welcome to batterygate and chargegate. Are you going to join the class action?
So glad to still be on V8:D
Chaserr
Hyperactive Hyperdrive
Sep 5, 2017
2,667
6,537
Logan
And in the only known case where the actually locked out existing capacity, i.e. the Note 7, they did so with the announcement that they want you to return it for a 100% full refund.
We don't even want that much, we just want the lockput removed - and if they can't for safety reasons they need to tell us why our cars are unsafe and why they're hiding that fact from us.
Keep an Wifi Access Point in your car at all times, not connected to cellular. Set up your car to use it, and it will auto connect every time you park but release when you're driving. This will keep you offline when parked, but online when driving only because you will be on 3G/LTE in D but on the offline WiFi while parked. Tesla engineers are manually remoting to people on V8 lately and downgrading them to v10 and we think it's related to batterygate but they can't install while you are in drive - the most they can do is command teh car to download an update but it can't be started while you're driving and they can't connect if you have a null WiFi blocking their accedd in P. If they find you, you'll get slower supercharging and the UI downgrades for certain, and maybe downgraded to 60 kwh capacity and slowed too. Good luck keeping your car on v8! I wish I had!
And in that only known example, they reduced pack voltage and locked out capacity because batteries were exploding.... just like Tesla batteries were right before 2019.16 was released in response to battery RUDs in what TEsla calls "an abundance of caution"
We need the NHTSA to complete its investigation fast because those phones were all recalled - reduced voltage wasn't considered a fix.
this post is correct. I’m bound by multiple NDA. So can’t name names. But locking out capacity isn’t just for safety it’s to extend the life of the cells and packs.
If you have a MacBook check your settings about Power. You will see the design capacity and remaining capacity. (Try coconut battery app) There you get a window into battery aging. Smart battery charging has been around for 2 decades and it keeps improving. Tesla I doubt is being malicious over the throttling and capping which is what this is. I think mountains of data over 7+ years and a couple hundred thousand cars, Tesla is managing batteries similar to our portable electronics
Droschke
3,319
5,206
Future
From that, I infer that it can be for safety reasons. In which case, they need to explain why the packs might not be safe, and that's when the topic of warranty replacement comes up - something they seem to be trying very hard to avoid.
I agree, it's for safety and for longevity. Not lowering the top end voltage/cell as it ages will result in swelling of the cell (ok cylindrical cells rarely swell, so lets convert that to instead) heat and gas evolution from within the cell and eventually unchecked, will cause cells to vent and possibly catch fire. It's a fact of lithium technology in batteries these days.
Reactions: Droschke
