Posting here as there is a lot of short various threads about this and am hoping to have one place to post about this.
3500 miles. Mine sounds exactly like a bad sway bar end link. Sort of a medium pitched clunk from front passenger side. It happened very rarely at first and I didn't give it a ton of attention. Then over the weekend we stayed somewhere with cobblestone driving areas and now it's more noticeable but not 100% repeatable. I have historically had REALLY bad luck with dealers chasing this sort of thing down. It either has to be bad enough to say "drive over a speed bump at an angle to reproduce" or else they either insist it's fine or start playing parts darts. I do run the car pretty hard in the mountains but am very careful over speed bumps and gradient changes. I've never hit a pothole or anything like that.
Things I plan to check before sending it to SC:
1) remove hubcap
2) check hood bolts
3) check for pebbles in brake shield etc
4) lift car and check sway bar links (it does have a front sway bar, correct?) and other susp bushings
1) remove hubcap
2) check hood bolts
