It’s me again, the annoying guy dreaming about air suspension.... To those that have accepted delivery, can you please speak to the ride quality of the car? Is it overly rough? Or stiff in a sporty way? I have never driven the Performance...
Thanks Eddie for mentioning your thoughts!
OK, here’s the thing:
Just as soon as you push it hard or you have bumps you can feel how it’s kind of riding on it’s bump stops
As you go into compression the spring rate gets dramatically higher
The car is tuned for a decent ride under slow or moderate driving conditions and smooth roads
When you get deep into the bump stops it wants to sort of pop back up, and this tends to make it a little bit skittish in bumpy corners
I actually got a little out of sorts coming around the corner last night and I think the lack of steering feel led me into overcontrolling it. Hard to judge the countersteer without that yaw feedback through the wheel.
Part of it could be the stability nanny cutting in as I correct, or bad alignment.
This car does have some significant torque steer.
I’ve only have 80 miles on it, but whatever it is i find this car hard to place precisely in low speed corners, worse with accel/decel, but it is not as bad when in track mode.
Apparently there is no way to use the Nav in track mode?
The ride is a little rough.
MPP makes bushings that are supposed to improve steering feel, going to have to get those, and their coilovers for sure.
You probably need full suspension and more rubber to get the handling even close to the power this car has.
It’s kind of a drag racer!
