I got the car in August 2022. The AC started to smell bad (sour smell) after about 3 months. I tried to change the filer, did not help at all. I sent the car to the service center, they used a machine with Airco Clean in the cabin, and replace the filter again, cost me $236. It did not improve at all. The weird part for my M X is the smell only appear when the AC is on outer loop and the smell is even worse in the rainy day. There is no bad smell when the ac is on inner loop. Could it be the HEPA filter? I remove the trim and saw the HEPA filter for the biohazard mode is right behind the air intake.
Another issue for my car since I got it, is the ac will cause vibration. No pattern has been founded yet, the vibration will go right away if I adjust the fan speed or any AC function. And will go back after about 5 seconds. The vibration can only be noticeable when the car is stopped.
Please share me any information if you have the same issue.
