At wide open throttle? Or light acceleration? Ours vibrate under light acceleration, but not when floored .Picked up 2022 MSLR today. Definitely vibrates when I punch it. Sadness.
Wide open, light acceleration is fine.At wide open throttle? Or light acceleration? Ours vibrate under light acceleration, but not when floored .
Sounds like the issue I had on my LR Was fixed by replacing the half shafts.Wide open, light acceleration is fine.
How long did they have the car?Sounds like the issue I had on my LR Was fixed by replacing the half shafts.
2.5h at Mt. Kisco, NYHow long did they have the car?
Not bad! That’s a little reassuring wow2.5h at Mt. Kisco, NY
Ah lucky! Sounds fixableWide open, light acceleration is fine.
Man hope you’re right. So far the SA said “it just needs to get broken in” BSAh lucky! Sounds fixable
Did it sound like mine? It's not the SA you want to speak to, it's the service center make an appointment in the app).Man hope you’re right. So far the SA said “it just needs to get broken in” BS
Yeah the SA just followed up. I have a SC appointment in April I guessDid it sound like mine? It's not the SA you want to speak to, it's the service center.
I have not noticed this yet. Will be monitoring. Plaid, Black, cream & walnut interior. MF451…,10/21 build. Delivered 10/29/21. 3036 miles.This thread aims to capture sub model (dual and trim motor) vibration occurrences for "refreshed" Model S cars. Please comment with as much information you can, should your car have this affliction (including VIN range).
Issue Description:
Vibration felt in accelerator pedal and sometime in yoke; passengers may also feel it on the floor and through
the console.
- Occurs: between 38 - 50 mph
- Conditions: Constant speed (e.g., holding 43 mph +/-), or under very slight acceleration in this range, especially after transition from regen
to slight acceleration (bit of gray bar)
- Frequency: Occurs more than 50% of the time
Related Threads:
POLL: vibration felt when slightly accelerating refresh Mode S Plaid or LR
Poll: 3x - 4x mph Refreshed Model S (LR and Plaid) Vibration issue build / VIN ranges
Plaid Vibration around 38-42MPH....
2021+ Model S and Model S Plaid Refresh Issues Thread
Hmm. Almost same as mine. Built around the same time. 21s? Or 19?I have not noticed this yet. Will be monitoring. Plaid, Black, cream & walnut interior. MF451…,10/21 build. Delivered 10/29/21. 3036 miles.
But has anyone been told what is causing it?! Fixes aside. Identifying the root cause must occur before a fix. If they still do not know the root cause, a fix will be a long time coming, if ever. Seven years to sort of temporarily fix the shutter issue on the last version of MS. PoS and afterthought front DU design, carried over to Raven and now Palladium. BOHICA.I just had my Plaid into the Miami SC today for something else and asked them about the vibration issue around 40 mph. They said Tesla is aware of it, working on it, but have not found a fix yet.
Noticed this on my new X Plaid delivered last week. Only observed on one drive so far. Any other reports from X Plaid owners?
SC did not tell me or even suggest the root cause. They seem in the darkBut has anyone been told what is causing it?! Fixes aside. Identifying the root cause must occur before a fix. If they still do not know the root cause, a fix will be a long time coming, if ever. Seven years to sort of temporarily fix the shutter issue on the last version of MS. PoS and afterthought front DU design, carried over to Raven and now Palladium. BOHICA.
My SC Service Manager told me the refreshed X has it for certain, as well.yes, I have seen reports of the X Plaid vibtrating on this thread or a related refreshed S "vibration" thread. Now that the X Plaid models clearly are also affected, hopefully for everyone's sake this issue is elevated to the highest priority at the mother ship.
