WilliamG
Hinge Fanatic
I'm not, actually. Driving in Plaid mode doesn't increase your Wh/mi. That's your foot that does.There's something to be said for getting 4 miles per KwH.
Almost there at 251 wh/mi. You probably are more like 521...
I'd be tempted though...you must have more control than I have.I'm not, actually. Driving in Plaid mode doesn't increase your Wh/mi. That's your foot that does.
Yes. That's my point. You're doing yourself a disservice buying a car with that kind of power and never using it. Genuinely, what's the point? There are MANY much nicer cars out there with less power...I'd be tempted though...you must have more control than I have.
Here we go. Lifetime Wh/Mi... 100% Plaid mode.I'd be tempted though...you must have more control than I have.
This is how it starts. And then they'll say it's normal operation since they all do it.Took delivery last week and mine does have a little bit of vibration around 35-40mph. Dropped it off and these are the notes in the app.
At least they acknowledged it…
(Also a Plaid)
YepThis is how it starts. And then they'll say it's normal operation since they all do it.
Any update on the parts if Vibrations is back?
And pause it should give you.Getting closer to pulling the trigger on a new MSLR after the most recent price drop. This vibration thing is giving me pause, though, assuming it's still a common issue with newer builds. How bad is the vibration actually, for those that experience it? Slight annoyance, or is it making you regret buying the car?
I did test drive a LS recently and didn't notice anything, but I wasn't looking for it at the time.
For me it’s a slight annoyance, for others on this thread it seems to be a major one. I’m mostly annoyed by the fact that my Plaid was vibration-free for about 15k miles until Tesla worked on my suspension. But honestly i barely feel it on a day-to-day basis. Maybe it’s because I rarely “accelerate gently”Getting closer to pulling the trigger on a new MSLR after the most recent price drop. This vibration thing is giving me pause, though, assuming it's still a common issue with newer builds. How bad is the vibration actually, for those that experience it? Slight annoyance, or is it making you regret buying the car?
I canceled my order on a refresh over both vibrations.Getting closer to pulling the trigger on a new MSLR after the most recent price drop. This vibration thing is giving me pause, though, assuming it's still a common issue with newer builds. How bad is the vibration actually, for those that experience it? Slight annoyance, or is it making you regret buying the car?
I drive a 2017 LR S that I bought new. At least my S only had one vibration issue and is manageable. The pre-refresh AWD MS only has the front half shaft vibration issue aka shudder on hard acceleration. It can be remedied w lowering links or replacing half shifts every 20,000ish miles.
As far as I can tell from the forum the refresh MS have an additional vibration that occurs at moderate speeds without acceleration and there is no fix. I would not recommend a new S. If I really wanted a new EV close to the capability of an S (capacity wise for cargo and people) I’d get a Y. I decided to keep driving my 2017 S
Yep, refresh vibration = expensive junk.I canceled my order on a refresh over both vibrations.
My odo reading the same as yours, why don't I have the vibration yet?
