Yes. Tried all the setting, except the one that works.Did you try the opposite, high, to see if it was worse?
Getting mine replaced on the 4th. We will see. I have two ranges of vibration. 38-44 and 70-78. Both under power/acceleration. Nothing on coasting/regen.
Great share, thanks!Just had my front half shafts replaced today. Solved the vibration issue in both ranges. Tech was clear that this is not the final solution and the issue will probably return. Replaced so they could send the half shaft to Tesla Engineering for testing.
Was the tech able to describe the specific issue with the half shafts that was causing the vibration?Just had my front half shafts replaced today. Solved the vibration issue in both ranges. Tech was clear that this is not the final solution and the issue will probably return. Replaced so they could send the half shaft to Tesla Engineering for testing.
Yes, like bent, twisted, worn CV joint, unbalanced, etc…Was the tech able to describe the specific issue with the half shafts that was causing the vibration?
Cause? Excessive torque…?Yes, like bent, twisted, worn CV joint, unbalanced, etc…
Could be, who knows? Need more data.Cause? Excessive torque…?
Not sure why the fronts would fail before the rears. The fronts probably have half the torque going through them compared to the rears. Unless the drive line is straighter in the rear?Could be, who knows? Need more data.
Maybe? They didn't change much on the car, just tweaked a few things and dropped in bigger motors, it seems. But, we're just speculating. No idea.I have not experienced this issue, yet.
However, I only have 2,547 miles on my 9/9/21 build MS Plaid, perhaps it’s because I have not launched it or pushed to its limits. Several “throw you’re head back” accelerations…
Saying this with no expertise…
That said…Here’s what I’ve been thinking.
Doesn’t seem like the Plaid is redesigned from the ground up, structurally.
Is it possible that Tesla built a machine that is too powerful for the structure it occupies.
If a person could magically run 0-60 in 5 seconds. Could the human body handle the stress? Or would bones shatter and muscle tissue & organs suffer damage.
Maybe the front shafts are half the diameter of the rears?Not sure why the fronts would fail before the rears. The fronts probably have half the torque going through them compared to the rears. Unless the drive line is straighter in the rear?
