Tesla stated in its official recall that overheating caused slow processing that caused other safety issues. It's also speculation, but it's more likely that the CAN Gateway didn't work correctly with the CPU that worked at the reduced frequency.You do realize the CAN Gateway in actually in the car computer module, right? The same car computer cooling system that is suffering from overheating. They are false errors and IMO are not coming from the various components/sensors throughout the car but are being triggered by an overheated car computer. If #1 and #2 are solved, I feel #3 is solved.
Even if this is not the case and the high temperature is a culprit, the high temperature didn't cause glitches in the computer in most cases. But the CAN Gateway glitched violently. This means that the CAN Gateway tolerates a much lower temperature than the computer. But it must tolerate the full range of temperatures that the computer module may produce to eliminate the possibility of such severe faults in principle. The CAN Gateway is a critical element of the computer module. It must fail last - not first! This is a car, for God's sake, not a gaming console.
In both cases, this is the kind of problem that goes into issue #3 ("design flaw"). It needs a separate fix in the hardware.
Also, the computer module should have control over the cooling system to cool itself when needed. Apparently, we didn't have that too. And, probably, still don't have it.
