errr, yeah … I wasn’t trying to be 'drastic' or 'please' other drivers; yes I am aware that 'low' regen marginally lowers regen efficiency; and no I am not in the slightest bit bothered about it ..
My comment was to provide a solution to the opening question - something which no one else seems to have answered in the past 37 posts !!!
As for driving manners over here, you don’t pull out to overtake someone doing 60 on a motorway and then immediately appear to be slamming on the brakes once in front of them when the road ahead is clear and you're merely resuming a cruising speed of around 85. I personally really don’t like the sensitivity of the soft brake light that seems to flicker on with a mere -15kw of braking effect. I only want it to come on when I actually press the brake pedal. Each to their own I guess
I am completely with you PV4EV!!! I am thinking that most people who have replied to this thread came from driving automatic ICE cars and have little to no experience with a manual transmission or never learned to drive them properly.
Let me put this a different way: It is hard not to look like an absolutely rookie when driving a Tesla, given the way the brake lights come on so easily when you lift your foot off the accelerator. The vast majority of the world learned to drive on either a manual or automatic ICE car, neither of which requires one to feather the accelerator to avoid brake lights coming on. Put another way, in the cars that we've all learned to drive when you let off the accelerator the brake lights never come on. Driving behind a tesla driver is similar to driving behind a NYC cabbie - brake lights going on and off all the time. If you drove a manual transmission this way, short of race car drivers, you would look like an absolute tool that just learned to drive. Using the gears to slow your vehicle is the correct way to drive a manual transmission and in doing so, you need to engage the brakes much less often.
Almost all of the manual transmission cars, heck even tiptronic equipped automatics in a sport mode, have a very similar initial reduction of speed when you let off the accelerator, due to the gearing, and no brakes come on.... ever. Admittedly, Tesla's reduction in speed is slightly more dramatic initially and substantially more so the longer you coast, but do we really need to blare lights each time we let off the accelerator? I don't think so.
I love the regenerative braking concept and absolutely want to take advantage of it, but I think there should be some middle ground - like a "Medium" regen setting - so that one can get some of the energy back, but not signal braking each time you slow down slightly. Or, perhaps allow for full regen, but have a 1 second delay on the brake lights when one lets off the accelerator to indicate, you know, that you are actually stopping. So, to use PV4EV's example, pass someone and get in the right lane, lights would only come on if you stayed off the accelerator for more then 1 second. Otherwise, you're alerting the person behind you, odds in they're in an ICE car, that you are stopping and therefore they should now start hitting the brakes...
