Regen Below Limit Today
Discussion in 'Model S: Battery & Charging' started by Todd Burch, Mar 25, 2013.
  1. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    After work today I started driving home and noticed something a bit odd.
    It was about 34°F and I had a limited regen arc (yellow dashed arc around 30 kW) because the pack was cold. However, as I was regenning (if that's not a verb we should make it one) I noticed that I was only regenerating at 15 kW instead of the 30 kW limit, despite regenning from a high speed (50 mph).
    Any ideas as to why I would have significantly less regen than even the yellow arc limit was indicating, despite slowing from a fairly high speed? No, I was not using the brakes.
  2. eelton
    eelton Member
    Chicago, IL
    I've noticed this before as well. I assume that, when cold, regeneration is proportionally reduced, not just capped.
  3. Todd Burch
    Smithfield, VA
    That seems silly. Why not cap? You'd be throwing away a lot of energy if true.
  4. K Hall
    K Hall Member
    Kansas City
    Battery performance is reduced when its cold. It's a common occurrence.
  5. Todd Burch
    Smithfield, VA
    Yes I know. Check the post again. I believe you misinterpreted the question.
  6. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    Any noun can be verbed.
  7. Todd Burch
    Smithfield, VA
    Well played, well played.
  8. K Hall
    K Hall Member
    Kansas City
    ah I see. It might not be a governor but a indicator of limitation. The yellow line that is. It could be a miscalculation.
  9. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    The yellow line is always shown too high. In fact, even when it is not shown at all you can still be limited to 50 kW regen. Then as the pack warms up further you finally get the full 60 kW.
  10. FlasherZ
    Even when my yellow line is gone, I notice regen can be limited to 30 or 45 kW.
  11. strider
    strider Active Member
    NE Oklahoma
    You could also have been traction-limited. Tires don't grip as well in the cold and the car will adjust regen based on available traction.
  12. Todd Burch
    Smithfield, VA
    I was nowhere no a traction limit, so don't think that was an issue. Clear, dry pavement, and less braking force than standard regen.
  13. wjhepworth
    wjhepworth Member
    North Bethesda, MD
    I have noticed the same effect. Seems to be related to temperature. It has happened a couple times to me so far this winter and it seems to stay there until temps rise. My follow up question would be around the fact that I thought the car kept the batteries warm. I am guessing they keep the battery "just warm enough" to avoid wasting energy.
  14. scottm
    scottm Legacy account
    Canada
    regen'ing
  15. Todd Burch
    Smithfield, VA
    Was I enduring the process of regenification?
  16. whitecotton
    whitecotton Member
    Houston, Texas
    I hate to bring back this thread but an important thing to realize Is when you drive in the cold all the cold wind is hitting the bottom of the battery pack so it might actually cool the pack just enough to push you to the next threshold of regen limits until it warms up again.
