  • We are looking for another podcast participant who can act as a lead co-host to join the TMC Podcast. If you are interested in participating please see this thread.
Regen braking capped at charging level or battery capacity?
I think I understand this, but just want confirmation. I’ve noticed that I get the regen braking reduced message a few minutes after starting every drive in the morning (I live on the top of a small mountain/ big hill). I know this can occur when the battery is near capacity, but I’m only charging to 85%. Is it the case that regen braking actually uses the charging cap rather than 100% battery capacity as its threshold?
I don't think it uses the charging cap because I regularly charge to 75%, but never see that message.
Fourdoor
1,989
2,149
United States
Yeah, somewhere between 85% and 90% (in warm weather) is where you start getting that message, it doesn't mean regen is eliminated, just that it is reduced, and the left edge of the left bar will be dots instead of being solid... the higher your state of charge goes the more dots / less solid line you have indicating that you have less regen available.
Keith
jjrandorin
Moderator
Nov 28, 2018
18,105
24,582
Riverside Co. CA
No, it doesnt use the charging cap as a regen threshhold. It limits regen to protect the battery from being charged at full regen for a variety of reasons, like temperature of the battery, or capacity of the battery.
240vPlug
1,347
976
Maryland
Right there are different scenarios where Regen will be limit. One less common case is when you doing a lot of hard acceleration and hard Regen. The more you do that you may notice Regen is limited.
Most common cause of limited Regen when charged <90% are cooler temps. I notice it below 45-50 F . The colder the temps the more it's limited.
Lastly at a high state of charge the battery is limited in the rate of charge and so also Regen to protect the battery.
240vPlug
1,347
976
Maryland
Somewhat related question. Does regen breaking use Tesla vision or USS to stop for cars in front of you, stop signs, or lights? I.e. does it use its sensors to adjust the rate of stopping?
AP or TACC use vision to adjust vehicle speed which includes both Regen and friction brakes. Regen does not use any of those sensors on its own to my knowledge.
