This is one of those "be careful what you wish for" items.I would love a regen-to-stop capability. Make it an option in the settings at least.
My reference is looking at the reflection in cars behind me at night. It appears that the brake lights only stay on when you are actively regenerating, and as soon as the car comes to a stop the brake lights go off unless you are holding them.I thought the brake lights stay on. You confirmed they don't? I seem to recall checking they did, but that was early on, it's possible that was changed with a later software update. Still, that doesn't seem like a valid reason from a design standpoint--the computer should be able to smooth all of that out and it be invisible to the user.
I had the Model X overnight, and I noticed at least once that when I took my foot off the brake it started rolling back slightly. Maybe because it's so heavy?
The brake lights on regen braking are triggered by deceleration. If they weren't they would flash all the time. As it is, it works just about perfect. If you are braking hard with regen the lights come on, which is what you want to alert the other drivers. In 70+K miles I've had zero issues with cars behind me not understanding what I did.My reference is looking at the reflection in cars behind me at night. It appears that the brake lights only stay on when you are actively regenerating, and as soon as the car comes to a stop the brake lights go off unless you are holding them.
Wouldn't total non-use of the braking system cause (over time) issues with the hardware? I'm thinking of rusted disks, sticky calipers, etc.
Any particular reason? Under about 10 km/h there is almost no kinetic energy to capture (given that regen doesn't capture it all). So the way to do it would be to simulate regen by using power from the battery to slow down the motor. Sounds inefficient to me.You can see when you r rear brakes are on by looking at the car image on the instrument display. They stay on when the car is stopped with "hold" activated. but that's not my issue, I want regen to persist until the car stops.
I would disagree that a 5,000 lb car slowing from 10 km/hr to zero has no kinetic energy to continue to recharge the battery. Try stopping your car with your bare hands at 10 km/hr and see how much kinetic energy it dissipates into you.Any particular reason? Under about 10 km/h there is almost no kinetic energy to capture (given that regen doesn't capture it all). So the way to do it would be to simulate regen by using power from the battery to slow down the motor. Sounds inefficient to me.
You have to consider the losses, what's left is very little, so the rate of stopping will need additional power input to keep the same deceleration.I would disagree that a 5,000 lb car slowing from 10 km/hr to zero has no kinetic energy to continue to recharge the battery. Try stopping your car with your bare hands at 10 km/hr and see how much kinetic energy it dissipates into you.
I agree with you except for your last sentence. In one sense, an important one, a single pedal normal operation is problematical. That is that no other motor vehicles normally operate in a single pedal fashion, and the braking function needs to be an instantaneous nearly reflex action by drivers to cope with emergency situations. Until there is level 4 autonomous driving the recourse to the driver must be absolute.I...
So in every aspect it makes a lot of sense to have the car come to a stop using one pedal and be consistent in all situations.
Even the first one might require a brake pedal in some cases. I suspect it's better to to know that you will have to press the brake pedal to come to a complete stop. That way you'll be thinking about it (even if only subconsciously) and it becomes a habit.I think there's some confusion. You identify two different driving conditions above: Normal vs emergency. D99 is referring to the former where, from a safety perspective anyway, having consistent off throttle decel is certainly better. There are plenty of non-emergency situations where pucker factor gets elevated a step or three when off throttle decel doesn't respond as expected.
I don't think there's any debate that the later requires the brake pedal.
Absolutely. I think the fact that BMW made a car with only an accellerator and no brake pedal is a major safety hazard. I simply cannot believe they got approvals from the government to release such a dangerous vehicle!I agree with you except for your last sentence. In one sense, an important one, a single pedal normal operation is problematical. That is that no other motor vehicles normally operate in a single pedal fashion, and the braking function needs to be an instantaneous nearly reflex action by drivers to cope with emergency situations.
