Regen braking weakened?
M396
7
3
Toronto
Noticed my regen brake is much weaker than before. Usually I don’t need to use the brake on speed bumps or turns at moderate speed but I used the brake for majority of my trip...Anyone else experiencing this? A regen brake temporarily reduced message kept popping up. I haven’t driven my car in a couple of days and battery is at 70%.
Updated software to 2020.48.30
Reactions: SlimJim
glide
3,698
3,860
Is it cold where you live?
If so, there’s your answer.
Space_CowBoy
63
43
Montreal
I experienced the same thing this morning for the first time. The only difference I can observe is that I didn't have my car plugged in overnight. I actually had full REGEN available (no dots) when I noticed coming off the highway. No message either. It was weird since it's the first time I had to use brakes when coming to a stop sign after I took my exit.
Temperature here is -3C/26F and the car warmed up for 20mins prior to my departure. Not exactly sure what caused it today.
JulienW
2,587
2,827
Atlanta
Is it cold where you live?....
In Toronto.....Florida?:eek::D:D:D
Reactions: lUtriaNt
SSedan
2,948
2,328
Greenville Wisconsin
Temps below about 50f can begin to reduce regenerative braking.
The pack is heavy so it will lag temp wise vs ambient.
Also the heat pump equipped cars are being reported to over scavenge heat from the battery.
Nikomagirl
New Member
Mar 21, 2021
2
Reno
The regen braking on our car was one of my favorite features! I absolutely loved not having to brake and actually having to use the accelerator to go downhill. This keeps changing with almost every software update. It’s so annoying- and probably unsafe as I feel like I am getting into a different car after each update.
  • Disagree
Reactions: Gasaraki
Shelburne
184
136
Shelburne Falls, MA
Your strength of your generative braking will vary depending on the ambient temperature and your car's state of charge. This is not a flaw in the car, it's a simple matter of battery physics. The only way around it is to re-condition the car's cabin and battery before going out on cold days. But even then, if your car's SOC is close to max capacity, you will see a temporary reduction in regeneration. Again, there is nothing wrong or unsafe with the car. You just need to be aware of this.
