Regen limited due to cold today
Discussion in 'Model S: Driving Dynamics' started by cinergi, Nov 14, 2012.
  1. cinergi
    cinergi Active Member
    MA
    Haven't seen anyone mention this yet ... It was low 40's (F) today and when I got in my car, there was a yellow dotted line in the regen area indicating regen was limited. I was quite surprised, for two reasons (as compared to the Roadster). 1) It wasn't on/off and 2) it had to be a LOT colder outside for the Roadster to disable regen (I realize we're not comparing apples to apples here -- on/off vs. limited regen)
    Regen slowly increased and was back to normal within 10-15 minutes (I missed when it went back to normal).
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Wow, I don't believe my Roadster has ever gone into limit mode unless it was sitting for hours well under freezing. I guess the algorithms are more conservative in the Model S. I wonder if this is just increased prudence or whether there is a battery chemistry difference?
  3. cinergi
    MA
    Yeah my Roadster would need to set at below-freezing temps for hours. The Model S sat in ~43F temps for 7 hours or so, mostly in the sun (after being parked in 65-70F temps overnight). Interior cabin temperature while it was parked those 7 hours while the sun was up was 65-70F.
  4. Zextraterrestrial
    Humboldt/Los Altos
    The battery in the S is directly under vs the roadster in the 'middle' maybe that has a little difference wrt ambient temps?
    but more likely different control algorithms
  5. doug
    doug Administrator / Head Moderator
    SF Bay Area
    I was thinking along these lines. Also with that flat pack, the Model S battery has much more surface area per unit volume.
  6. jerry33
    Texas
    So some enterprising person, perhaps SoftAuthor, needs to come up with an easily removable bottom insulation solution.
  7. NigelM
    NigelM Recovering Member
    Northern Virginia
    Somewhat OT, but would extreme cold affect the touchscreen?
  8. jerry33
    Texas
    It will make it slower and perhaps dimmer.
  9. William13
    William13 Active Member
    South Bend
    My car had the same regen limiter the last few days in the morning. I hadn't thought about it. It moderated over a few minutes. Then the line disappeared.
  10. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    Or almost unusable...even the Prius screen in sub 20F is barely usable.
    Evan, Via Tapatalk
  11. Zextraterrestrial
    Humboldt/Los Altos
    just use some 3M crazy velcro on the edges and carpet tape for the center to mount a sheet of 10mm neoprene to the underside
    it might help some
  12. mknox
    mknox Well-Known Member
    Toronto, ON
    Was the car plugged in? If so, I would have thought that it would keep the battery at optimal temperature. Sounds like the 10 minutes of driving was needed to warm up the pack.
  13. jerry33
    Texas
    I think it keeps the battery warm and cold enough to avoid degradation. I don't think it keeps it within, say, 10C. That would take a fair bit of energy to do.
  14. mknox
    Toronto, ON
    Makes sense. I probably wouldn't want to pay for unneeded kWhs with the car plugged in for extended periods.
    I believe Tesla is working on the ability to "schedule" drive times to pre-heat or pre-cool the car while still plugged in so that you don't waste battery power and range starting out very hot or cold. Perhaps in this scenario they'll optimize the battery temperature too.
  15. cinergi
    MA
    It was not plugged in. The roadster would keep the pack heated when cold out and plugged in. It used a fair amount of power to do so. No idea what the model s does. I'm in a garage and no plug at work so I doubt I'll get the chance to find out.
  16. mknox
    Toronto, ON
    I'll be in the same boat (no place to plug in at work) when I get my car.
  17. Francis Lau
    Francis Lau P-1456
    Bellevue, WA
    A newbie question, why is there a limiter when it is cold?
  18. eledille
    eledille TMS 85 owner :)
    Oslo, Norway
    The chemistry changes when the battery is cold. The lithium tends to precipitate in metal form on one of the electrodes, I think. Anyway, the batteries will degrade rapidly if charged when very cold.
  19. KBF
    KBF Model X owner (formerly Cdn Signature Model S)
    Steinbach, MB, Canada
    What, Toronto businesses don't have block heater plug ins for employees? Out here there are 110v plugs all over the place, since an ICE can have a hard time starting after sitting for 8 hours or so on a cold day. One reason Manitoba should be great for EV's; we're used to plugging in our cars all winter anyway!
  20. brianman
    brianman Burrito Founder
    Keep in mind a full charge on lowly 110 takes about 65 hours. ;)
    Charging Model S | Tesla Motors
