Regen on AWD model S
Discussion in 'Model S' started by William3, Jan 14, 2011.
Tags:
  1. William3
    William3 Member
    I'd like to see stronger (than the Roadster) regen on the Model S AWD model. Regen on the Roadster is limited because it is in the rear (and potentially only one tire). Anyone notice how fast the Roadster rear tires wear out? I think the regen contributes to that more than anyone seems to mention. Having regen on both the front AND rear will really help reduce tire wear and allow for stronger regen (if Tesla allows it).
  2. tdelta1000
    tdelta1000 Active Member
    South Florida
    Hey William I would like more information on the subject. Can you offer a link? Thanks
  3. TEG
    TEG TMC Moderator
    William3, I think you might be jumping to conclusions for reasons why the rears wear out faster.
    My guess it has more to do with suspension tuning, and the forces on the driven wheels for a car that can accelerate so quickly.
  4. vfx
    vfx Well-Known Member
    CA CA
    I think the rears wearing out is mainly from the amazing torque. The equally amazing Traction Control allows just a little scuffing off of rubber on every spirited acceleration. It's safe, smooth and intoxicating so the temptation is to do it every time from a stop. Not so in other cars, too much lag, noise, fuel and smoke is emitted to do it all the time which results in not as much tire wear.
  5. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I thought a lot of it had to do with the actual tire. It's a very soft compound/max performance summer tire with a low tread rating. Of course the Roadster has a ton of torque as vfx mentioned with doesn't help tread life. The acceleration is amazing.
  6. TEG
    TEG TMC Moderator
    #6 TEG, Jan 16, 2011
    Early versions of Acura NSX had notorious rear tire wear. In some later years they revised the suspension tuning and increased the longevity of the tire.
    http://www.nytimes.com/1994/02/22/business/acura-tire-wear-comes-under-fire.html
    http://www.nsxprime.com/forums/showthread.php?t=93666
    Might Roadster be configured for handling over tire life?
  7. TEG
    TEG TMC Moderator
    (Might want to revise the title of this topic since it is more about tire life than AWD Model S Regen...)
  8. SByer
    SByer '08 #383
    Cupertino, CA
    Well, we know it's configured for efficiency. I'm not sure what implications that has - maybe it's a combo of the reduced toe-in letting the fronts live longer and less camber producing slightly more uneven wear - especially as the car, uhm, encourages a driving style that would normally want more negative camber, not less.
    But really, I'm not finding the rear tire life to be that much shorter than on the 911 (which wasn't that much different than the MR2). And the 2/1 ratio front to rear was the same on all three. The only annoying part is the wear bars are more disruptive in an EV.
  9. tdelta1000
    South Florida
  10. TEG
    TEG TMC Moderator
    I am not currently a moderator, so can't do that. (Hint to a moderator.)
  11. tdelta1000
    South Florida
    I second that motion...
  12. shark2k
    shark2k Member
    West Orange, NJ
    Wait, so what is the hint? That you want to be a moderator or to change the title :tongue:.
    -Shark2k
