Regenerative braking not working in cold?
Godzill4
52
14
Austin, TX
Anyone else experiencing regen brake not working in the cold? I'm here in Texas and it gets no where near as cold as up north and I find it surprising that regen brake isn't kicking in till i hit about 20-30 mph.
Thoughts?
gfb107
209
99
Cary, NC
Have you charged to 100%? Regen won't work with 100% charge, as there's no where for the electricity to go. Once the battery drains a bit, regen starts working again.
Reactions: Johnmbureau
andrewket
5,704
1,525
Page 55 of the Model S manual:
"The amount of energy fed back to the Battery
using regenerative braking can depend on the
current state of the Battery and the charge
level setting that you are using. If regenerative
braking is limited, a dashed yellow line
displays on the power meter. For example,
regenerative braking may be limited if the
Battery is already fully charged or if the
ambient temperature is low."
This service brought to you by the Tesla Owners Club Mechanical Turk. "Cut and pasting from the owners manual for customers who won't RTFM since 2013." (c) 2017, all rights reserved.
Tam
8,261
7,115
Visalia, CA
That's normal. It doesn't wait for extreme cold or snow or ice in Southern California either (which doesn't get snow or ice in winter unless you drive up to those mountains).
abasile
Conscientious investor
We live at altitude and park our Model S outdoors, where it is frequently soaked in below-freezing temperatures. The trick is to pre-heat and/or charge the car shortly before driving it. That causes the car to heat the battery pack which means that we usually have at least 30 kW of regen available when we start driving. Even at 80% state of charge, we're then able to drive down the mountain (4900' / 1500m descent) with enough regen to stay off the brake pedal.
Reactions: BigMskiman
Godzill4
52
14
Austin, TX
ahh I see. I usually have my battery set to daily driving charge so it won't ever charge fully and it'll leave about 20 miles to full charge. Here in central Texas there are those rare days where it hits about 35 degrees or so and thats when I can tell that regen is slow to kick in. Nonetheless, Im glad you guys helped ease my mind!
Mine GO BOOM
32
37
Here
This past Sunday in NYC, I didn't get any regenerative breaking until I was about 20 miles into a drive. It was in the teens all day, so pretty cold. Previously with 40s temperature, I had at least a tiny amount of regenerative breaking at the start, so was surprised I had completely none. Side note, I discovered this car coasts like a boss, never felt so low of friction before even when putting my previous cars into neutral.
Missile Toad
581
530
Houston
I had a contactor failure at about 88 MPH. the S 70D coasted at least 1.5 miles until I applied friction brakes to stop it. It might be a little bit slipperier than the X.
gobowz
New Member
Feb 24, 2013
2
United States
Thoughts?
Im in Austin and I just noticed the same thing. Its about 35 degrees today. I was going to call the repair center. Ill just keep an eye on it for now.
Big Earl
bnkwupt
Jul 12, 2017
4,915
8,790
Springfield, VA
Don’t worry, it’s normal. You’ll start noticing regeneration limits when temperatures drop below about 45F. Overnight in 35 degree weather, expect very little regen to be available if you haven’t preheated the vehicle.
MBCottage
20
4
TX
Thoughts?
Hi, I’m outside of San Antonio... Regen stopped working Friday when it was HOT Mid to high 80’s Mine are hardly engaging at any speed. This morning it was 49 degrees no difference. I’m down to 80 miles and only charged it to 170 last Thursday night. Feels like rolling at Max Charge!
1375mlm
197
223
Texas, Houston
To be fair, my V9 has completely wrecked the manual feature of the car. Can’t access it, all I see are white blank sheets every time I try to access a section.
Not saying that there isn’t a hard copy, but it’s definitely less convenient
Maybe give him the benefit of doubt?
bell2041
171
56
Brooklyn
It just got colder here in NYC, and for some reason, I have limited regen with just 56F outside, and it's limited for like 15 minutes of driving with like 10 minutes of preheating before drive.
Is that normal? in this time 20 minutes I am burning 50% more energy (Avg. more then 600 Wh/m)
Big Earl
bnkwupt
Jul 12, 2017
4,915
8,790
Springfield, VA
Yes, in my experience, temperatures in the mid-50s are enough to limit regeneration for the first few miles of driving. The battery heater won't come on until the battery temperature drops below 45 or 50 degrees and it will only heat it back up to that level, so you'll always have limited regen when starting out in the cold, even if you preheat.
TexasEV
7,640
8,464
Austin, TX
It’s also online.
Darthbenji
1,003
594
Ontario
Happened today with a winter tire install. New tires and wheels. Mild temperatures, not fully charged. Went straight to the service center and they said it could be the new tires and the car learning them.
Big Earl
bnkwupt
Jul 12, 2017
4,915
8,790
Springfield, VA
What happened, exactly? Was regen reduced, completely turned off? Was there a warning message, and if so, what did it say?
Darthbenji
1,003
594
Ontario
No warning message. All appears normal on the display. No dots indicating reduced regen. Doesn’t work at speed. Kicks in at low speed only.
