Yup, my thinking as well. Unlike my wife who looks at the bumper in front of her and also keeps a lead foot until 20 feet before a stop sign, I look much further ahead, gauge the lights, traffic, etc. I get better mileage with low setting and she gets better mileage with higher setting. Preferably, I would like an even lower setting.I'm curious if people prefer standard or low. I use low myself, standard seems like way too much braking.
Having driven Tesla for 4 1/2 years, RAV4EV for 6, a person gets used to regen and usually wants more. "
It sounds like you have "creep" turned on. Go to Controls->Driving->Creep and select OFF.If you've ever driven a stick shift, regen is quick to get used to.
I wonder why it disengages at around 5 mph. Regenning to a full stop and then automatically engaging brake hold might take a little practice, but would be a nice option.
Remember, we have induction motors, which means you need a slip between the motor and field speeds to transfer power either way, and the magnetic fields aren't static. In regen, the motor has to be turning faster than the magnetic field is spinning.
I think it stops at 5 mph because the hardware can't effectively generate power below that speed. Tesla could give you the feeling of regen down to zero by powering the motor in reverse a little, but it would be consuming more power not absorbing more at the end and they chose not to.
I'm still not sure if the Bolt's regen to 0 is authentic - they have different hardware, which requires a slip angle rather than a speed differential, so in theory it might be possible to go to 0 - but it's equally likely that they are blending brakes into it; the car does regen on brake pedal application as well, unlike Tesla.
No. Not reverse power; just a smooth friction brake & hold after regen gives up slowing the car down.
AP already does this.
That'd be another design option, with an implicit linking of brakes to the accelerator. Tesla opted not to take that approach, either, at least so far. Clearly there a few ways the could choose to play this. My point was that they don't extend regen to 0 because they can't, so extending the regen feeling to zero would involve coupling in another system somehow.
…like when AP brings the car to a full stop.
