brucet999
Note that this applies to a normal car too. Normal cars have "regen" too! Obviously it doesn't actually regen, but releasing the accelerator entirely creates drag if you're above a certain speed, and if you have RWD then you'll encounter the same trouble as described here. And the solution is the same: shift into neutral.
From this, I take it that your ICE vehicles have been manual shift. Almost all automatic transmissions in "Drive" coast when you let off the gas. To get engine braking you have to deliberately shift into lower gears.
- - - Updated - - -
I've driven Model Ss through three winters. I have always left regen on "Standard" and have never had an issue as long as I was driving at an appropriate speed for the conditions.
From what you say, I would guess that you are adept at feathering the accelerator pedal such that you get regen only very gently if at all. Those who lift the right foot in order to be ready to use the brake pedal may experience abrupt application of regen.
