Whisky
From driving the car.
How do you know it's from SoC and not from the battery heating up from driving the car?
Being in the high desert mountain foothills, it's no surprise that you're seeing regen limits this time of year.About half the time when I put the car in "D" I get the message "Regenerative Braking Will Be Limited" after a few minutes it goes away and for a while It doesn't really seem to work normal (I have selected the "Standard" mode). Anyone else see this? Any idea what it is trying to tell me? I looked in teh manual but haven't found any information. Thanks.
It could be. If supercharging was free I would try to charge to 90 and see if I have regen. In past experiences I have has some regen limitation when charging to 90 from WC and leaving for the day even during the summertime.How do you know it's from SoC and not from the battery heating up from driving the car?
IHow do you know it's from SoC and not from the battery heating up from driving the car?
Been doing some research on this... how do you know this? I've been having trouble finding a source
Heating the battery a bit from that ambient temp actually helps. Battery seems to like closer to 80F (trade off occurs w/passengers wanting A/C).How do you know it's from SoC and not from the battery heating up from driving the car?
It appears Tesla batteries are happiest around 30°C, but accept the highest charge rate at around 50°C.The temperature effect on regen braking is much more dramatic with my M3 than I expected. 60F in Toronto at 50% SOC and I get the limited regen warning with the dots passed the D. We also have. A Nissan Leaf, which has a very nice one pedal driving feature, and we don’t see the drop in regen until you get below freezing. The Tesla is a more advanced vehicle, so it is hard to explain why it is more limited in this area.
What was the temperature over the prior 8+ hours? The thermal mass of the battery pack is pretty significant. On a relatively warm autumn day, the battery may still be cold if it was parked outdoors or in a cold garage overnight. However, if the battery temperature is actually 60F / 16C, then I would be surprised if regen is being limited at 50% SOC; that would be unusual.The temperature effect on regen braking is much more dramatic with my M3 than I expected. 60F in Toronto at 50% SOC and I get the limited regen warning with the dots passed the D. We also have. A Nissan Leaf, which has a very nice one pedal driving feature, and we don’t see the drop in regen until you get below freezing. The Tesla is a more advanced vehicle, so it is hard to explain why it is more limited in this area.
It takes some time to heat such a large mass.That could be it, we have had some near freezing nights, and that is a large battery mass, but I thought the active temperature management would bring it up quicker.
With the single pedal driving on the Leaf (which I think Tesla should copy) mechanical brakes are seamlessly brought in as needed to supplement regen, when you let up on the accelerator. So you don’t notice any regen fade, and don’t need to be warned braking will not be what you are used to in warmer weather. Can anybody see a reason Tesla should not do this as well?
I like Tesla’s current system, as it helps me to use the mechanical (friction) brakes as little as possible. If I see that less regen is available, then I can leave more room to slow down, and I don’t have to worry about inadvertently using the brakes as I lift off the accelerator. This is particularly important when descending mountain grades regularly (as I do) because you want to minimize wear and heating of the brakes. In general, it’s helpful for efficiency and maximizing range.That could be it, we have had some near freezing nights, and that is a large battery mass, but I thought the active temperature management would bring it up quicker.
