Regenerative Braking
Discussion in 'Model S: Driving Dynamics' started by speedyellow08, Oct 29, 2013.
  1. speedyellow08
    speedyellow08 Member
    houston
    I notice a big difference in the regenerative braking between my previous 40kW and the new 60kW. My 40kW used to stop much quicker. Did anybody noticed this after upgrading from a lower kW to upper kW battery car?
  2. Zythryn
    Zythryn Model Y custom Warming Stripes wrap.
    Minnesota
    I don't notice much difference, if any, between our 60 and our 85.
    Did you check the regen setting?
    If anything, I would expect the regen in the larger battery to be stronger.
  3. Red
    Red Member
    earth
    Check the regen settings. It could be you simply have the milder of the two settings activated now.
  4. J in MN
    J in MN S60 P12635
    Minnesota
    Nope, the lighter 60 kWh battery has stronger deceleration until you slow down below the 60 kW point, then they are both the same (0.15 g).
  5. vitaliy
    vitaliy Member
    Tysons, VA
    If Model S is charged to 10% vs 90%, will amount of regenerated energy be the same?
  6. jerry33
    Texas
    Do you mean 10% or 100%? If 10% yes, I've never noticed any difference as long as there was enough space left in the battery and the battery was warm enough. If 100% or close to it, regen will reduce or stop since there will be nowhere for the electricity to go.
  7. vitaliy
    vitaliy Member
    Tysons, VA
    That's good! I just though if supercharging is slower when battery is closer to 100%, so will regeneration...
  8. jerry33
    Texas
    The maximum regen rate is 60 kW. Superchargers can be up to 135 kW.
