On a rear wheel drive unit the front wheels should freewheel if jacked up? Do the front wheels freewheel on an all wheel drive if jacked up (I think they should)? Neither has a parking brake on the front wheels? If you unplug the connectors to the electric parking brake on both sides and apply 12VDC, do the brakes stay retracted after removing the 12V source?
If the pyro fuse is blown and you still have 12V power can you put the car in tow mode via the center screen? With the pyro fuse blown the DC-to-DC 12V converter could not supply 12V; therefore, if you removed the 12V battery negative terminal, would the car remain in tow mode (parking brake released)? Normally the car exits tow mode and sets the electric parking brake after 10 minutes. If the car does remain in tow mode, I guess you could temporarily connect a jump starter across the 12V battery terminals even if the 12V was removed/disconnected.
Maybe someone has done or should do a Youtube video on how to move a bricked Tesla car without a tow truck flat bed.
Thanks in advance for confirming any of the above. Please correct anything in error and add additional info as necessary.
