Thanks for the info, I got my car imported to UK with HK setting.
Initially the car didn’t have any data connection due to the HK Tesla SIM don’t support roaming.
I then change the SIM to a local carrier O2 monthly plan, rebooted the MCU and I have data for Spotify streaming, MCU Google map and traffic info. I can access the car via the app.
I even got a software update a few days later after I connected the car to my home’s wifi.
This update still had the HK region restrictions, i.e. no web browser and calendar.
What I don’t have:
Turn by turn Nav, cause the car still have the HK Map data.
Auto pilot see the UK speed signs as KPH, even with the unit set to MPH, it will translate it from KPH, eg when it see a UK 50 sign, the Instrument Cluster will show 31 MPH.
This should affect the autopilot cursing function as the car will drive or cruse at the wrong speed.
Spotify still can play with the Tesla account but will play HK locale playlists.
With the help of the guys above we managed to update the region setting for the car and update the map data for UK. (6-7GB worth is map data alone!)
Now the speed data is read with a MPH base. This will enable correct autopilot function.
It also now have the turn by turn UK nav.
Also the car nor have the web browser and calendar app.
However the Spotify won’t work.
It keeps on loading and even say the Tesla account is invalid. I then tried with my own premium ac, which can be logged in, but I still can’t stream any songs.
All other data works, so it’s not the wifi is SIM card.
It’s either the app (region locked?) or connection with Spotify server, but it was streaming when it was in HK region setting.
I’m still working on that.
I update if we manage to fix this minor problem.
I have not tried SC, I expect it to work and will update when I have the chance to try.
TBH in UK the use of SC is less likely unless you live right next to one. Mostly you charge at home or local paid charging points.
Once again thanks TK, I would recommend anyone moving their car to another region to contact them for pointers!
