Remote app and seat warmers
Discussion in 'Model S: User Interface' started by Reddy Kilowatt, Feb 20, 2021.
  1. Reddy Kilowatt
    Chantilly VA
    I have a 2020 M S and I can’t get the seat to warm up with the phone app. The steering wheel heats up as well as the other climate features. I just can’t get the seats to warm up on any setting. I have deliberately tried several settings which do display in the car when I get in. So I know the app works but the seats just don’t respond until I sit in the car. Then they are slow to catch up so I notice they are stone cold but do work once I’m in the car.
    I have had the car into service twice. The last trip the service manager told me to remove the USB, dump and reload the APP, which I did without any success. I’ve even got an update since going to service this week.
    As I recall my old M S would preheat the seats before sitting in the car. I also remember Tesla disabling the steering wheel heater years ago to deal with some other software issue.
  2. dark cloud
    dark cloud Active Member
    BC
    so once you are in the climate screen you click on the seat in the app, the 3 lines on the seat light up in the app, but it doesn't actually warm the seat?
  3. Reddy Kilowatt
    Chantilly VA
    Correct, I’ve even tried one, and two bars, no luck there either. The in car display matches the remote app. Temp changes or heated steering match and work. Only the seat warmers do not work.
  4. random155
    random155 Member
    NJ
    The seat warmers are so weak in these cars that they are probably turned on but you cant feel them until you sit on the seat for a few minutes and the heat transfers through the layers of seat material. Mine acts the same way and that's how I have rationalized it in my head. After pre-heating for at least 20 minutes I cant just sit in the car and feel instant heat on my ass... its weird.
  5. Reddy Kilowatt
    Chantilly VA
    Normally I would agree with this but my seats are stone cold. As I recall my 2018 S didn't have this issue. When I got the car back from Tesla they told me to dump the App and replace the USB and try again. No Luck.............. Wit that I would have to say something is wrong. Unless there is a difference between my new seats and the 2018 seats, which I don't think there is.
  6. krsgio
    krsgio Member
    Colorado
    I thought I remembered a vid of youtuber daerik showing his seat heaters with a thermal awhile back but I have similar experience as you OP. I can remotely condition the car with seat heaters on, steering wheel ect. When I get to the car only the temp and the wheel feels like it actually conditioned. But eventually after sitting in the car long enough the seat does begin to warm.
  7. ICUDoc
    ICUDoc Active Member
    Sydney NSW
    Maybe they don't warm at all unless they sense a bum on hem, using the seatbelt sensor?
  8. beatle
    beatle Member
    Springfield, VA
    I just did a little test. I turned my climate on for half an hour and then went out to check the seat temperatures with an IR thermometer. I set the driver's seat to 3 bars and left the passenger seat off. The passenger seat was 64 degrees and the driver's seat was 84.
    I will say that the seat doesn't feel as warm as I thought it would be, but the seat heaters do come on.
  9. TMeister
    TMeister Gearhead
    Boise, ID
    Mine behaves as you describe as well. The steering wheel heats up but seats do not when set in the app. It used to do this last winter but many updates since then so likely a software change.
  10. Reddy Kilowatt
    Chantilly VA
    i would agree with your statement,but why doesn’t Tesla admit to it? It’s similar to the steering wheel feature software bug a couple years ago. They had me remove the USB and reload the app,which didn’t work.
