raymond
"This car has been reported stolen by owner-you have 5 miles to pull over to a safe location".
And then the max speed could come down 1mph per second or so. I'm pretty sure this can be done safely.
I think a feature that could only be implemented by Tesla (owner would have to call in and verify who there were-not foolproof of course) that would disable the car after X number of miles. I could send a large message on the 17" screen "This car has been reported stolen by owner-you have 5 miles to pull over to a safe location".
Don't know if that would work with slightly more sophisticated "handshaking" protocols or not.
I dunno. The warning is likely to make the thief mad and cause him to damage the car. I'd think the best way would be to have the car slowly limit the speed so that after five minutes or so it's down to two mph. Then once the car senses that's it's stopped, shut down. Maybe also take a picture of the driver with the built-in camera.
That would be the idea. After a certain distance or time, the car wouldn't simply come to a stop (could be unsafe) but would drop to a low speed like you said. Then with sufficient warning it would stop.
Aren't most cars like this stolen by simply putting them on a flatbed and driven away?
That's probably much quicker than bypassing security on the car so this kind of system wouldn't help.
You only have to outsmart the computer or the human. Often the human is easier to outwit.an expansive imagination and some basic skills can outsmart 99% of computers out there these days.....
By suggesting a kill switch...
Whatever system is implemented, they should make it hard to simply trick the other person on the phone at Tesla into thinking it was you. I'm not sure what protocols could be set in place to do this though.
Password? Actually Tesla should already have enough information on you to ask a few security questions.
Or this:
Now these antenna's (and the required hardware) establish a link so that the car thinks the key fob is actually in the car. The car and the key fob - no matter how complex the protocol - can communicate through the two-antenna relay system just like they normally would with the key fob in car.
At the end of the countdown, the most annoying noise in the world would play continuously at 11......
This attack can be defeated by measuring the round-trip time to prove that you are in fact close (can't cheat the speed of light!). This technique is already used in (for example) some DRM systems - to enforce that you are playing your protected audio/video content on a nearby device, not extending it across the internet to someone else who hasn't purchased the material. (you may or may not like the objective behind this, but the technology works).
I don't know if it has been implemented in keyfob systems yet.
I thought all key fobs used a crypto key progression system, and repeating the same previous code definitely doesn't work. It would take exceptional knowledge of the algoritmm and creation of the next sequence code to get the car to accept it...
Also, what happens as the car drives away from the fob?
