2virgule5
Hi, I'm considering buying the app but I'd like to know if it manages several car on one account (we have an S and an X). Also, is summon possible from the Apple Watch? Thx.
Yes. If you press the Gear (cog) icon on the top-right, a list of your cars will show up. Then you can switch cars from there if they're under the same Tesla account. Summon is possible from the Apple Watch and there was a YouTube video of it posted by one of the Remote S users:Hi, I'm considering buying the app but I'd like to know if it manages several car on one account (we have an S and an X). Also, is summon possible from the Apple Watch? Thx.
Since Tesla now charges a fee for keeping your car plugged into the Supercharger station after the charge is complete, I added an alarm to Remote S that will play if this happens
Okay. I will add setting fields for you to tweak. One to set which charge % to start the alarm for. And one to set the kW minimum threshold before sounding an alarm.I'd like an alarm when the car has reached XX% - e.g. I might need 60% to continue my journey but charge limit is set to something higher, or an alarm at 60% gives me enough time to get back to the vehicle (e.g. facilities are some way away) in good time - particularly if I want to leave as soon as the car has enough juice
Current I sit watching my phone ...
I also sit watching my phone in case something unusual happens - e.g. kW drops unexpectedly
It's been added. Thanks for the suggestion.That would be brill. Many thanks.
So you can use the alarm even if it's not a Supercharger. Cool!View attachment 210981
That is correct. But keep in mind that Apple still restricts apps to only work when it's in the foreground. So the alarm will only work if you keep Remote S in the foreground. To save batteries, you can turn the screen brightness to the lowest setting and leave the volume higher (you only need the sound anyway). A scenario where this would play out well is if you're eating and don't want to keep staring at your phone and watching the charge % or kW power. You can just leave the phone on the table with Remote S open when it's around the time, enjoy your meal and the alarm will sound when the charge conditions are met. Or if you're like me and like to nap at the charger, you can keep the phone plugged into the USB and have Remote S wake you up when the charge conditions are met.So you can use the alarm even if it's not a Supercharger. Cool!
I just uploaded the new version with WannabeOwner's suggestion to the App Store a few minutes ago. It'll take a few days for Apple to review the app before posting the update.I'm not seeing a update available - I guess it's still in Apple validation?
- Battery current now displays correctly even if a charge cable is connected
- Supercharger current now displays when using Tesla's superchargers
- Battery current now displays the correct value when it is negative
Ah. Fix one bug and it introduces another. I'll fix it right away.The charging current seems to be wrong for me in the new version, only 4.5A when real charging current is 10A:
Voltage (224V) and power (2kW) is correct.
Be obliged if you would tell us what new bug you're going to introduce with this fix. Save us the trouble of finding it.Ah. Fix one bug and it introduces another. I'll fix it right away.
Not at all. Simply taking him at his word.I think you may be confusing Allen with Tesla.
Haha. No, this is a Tesla bug in the API that screwed things up for me in the first place. They recently started to report a charger_pilot_current value of 40 A for Superchargers. This confused my algorithm, because it used to report charger_pilot_current = 0 A for Superchargers, and in this scenario, I display to users the battery current instead, because the API for the Supercharger reports 0 A as the charger's current. But since the API started reporting 40 A for the charger_pilot_current, it made my app think that the Supercharger is a wall outlet, and so it started displaying the charger's current to the users (which the API reports as 0 A). So to fix that, I changed the algorithm so that the Supercharger would report the battery current again even though the API has an error in it. And that's the bug fix. The problem was that my bug fix accidentally caused wall outlets to report the battery current instead of the charger current, too.Be obliged if you would tell us what new bug you're going to introduce with this fix. Save us the trouble of finding it.
Interesting. Is the real battery voltage available too? Other values as well perhaps?So to fix that, I changed the algorithm so that the Supercharger would report the battery current again even though the API has an error in it. And that's the bug fix. The problem was that my bug fix accidentally caused wall outlets to report the battery current instead of the charger current, too.
I wish the battery voltage was available in the API but it isn't. I'm already one step ahead of you with the "extra" electrical panel and more decimal points for the power. When you're charging, close the command menu (top-left button) and you will notice two more fields on the top: The left value is the actual power going into your car's battery (this is calculated by looking at your car's battery current and multiplying it by the battery's voltage). It gives you the power up to 3 decimal points. So say it says 1 kW as the charger's power, the actual power going into your batteries could say .722 kW. (See attached image for this example).Interesting. Is the real battery voltage available too? Other values as well perhaps?
Maybe you can extend the app with an additional 'panel' with extra electrical values?
Is it possible to make the power value more accurate with one decimal perhaps? (in my case with 10A and 230V I would like it to show 2.3kW instead of 2kW).
Thanks for responding and submitting the bug fix quickly .
