Remote start to warm battery?
Discussion in 'Model S: Battery & Charging' started by salvatorej, Nov 9, 2014.
  1. salvatorej
    salvatorej Member
    NJ
    Hello everyone,
    I'm beginning to notice how my MS's energy consumption rises in cooler weather, particularly at the beginning of a trip, as the battery gradually warms up and becomes more efficient.
    Does starting the car remotely, as opposed to *just* pre-heating the car, warm the battery pack? In other words, if I want the car to have a warm and efficient battery ASAP in cold weather, will pre-starting it be more useful than using the remote app to pre-heat the cabin? Timing the charge so it's active just before driving seems like more of a hassle than just remotely starting the car.
    I understood remote start to be a useful feature if you have forgotten or lost your key fob, but if it also serves as a way to warm the battery in a way that climate control heating does not, then that would be good to know.
    Thanks
  2. salvatorej
    salvatorej Member
    NJ
    Well, I just realized that remote start only lasts for two minutes without hitting the brakes. Never mind.
  3. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR;YLR
    Colorado
    #3 stevezzzz, Nov 9, 2014
    If you can arrange to turn on the climate control 20-30 minutes ahead and finish charging
    just before you unplug, both the battery pack and car interior will be warmed using shore power. It makes a big difference to the energy usage in the first few miles.
  4. jerry33
    Texas
    Like Stevezzzz say, use the App to turn on climate control. Set the heat up to quite high (26C or so). Also set the timer so that the charging ends just before you start to drive. Also it helps if you turn off range mode (from the Settings screen) when you plug in the car. (I wish that you could adjust range mode from the App so that you could turn it off if you forgot.)
  5. stevezzzz
    Colorado
    I remember Cottonwood telling us that when range is an issue, after preheating the interior he actually turns off climate control for a while when starting out in cold weather.
  6. jerry33
    Texas
    Right. That's why you heat it up to warmer than you normally would.
  7. Brass Guy
    Brass Guy Active Member
    Holbrook, MA
    Ever since release 5.9 (according to the change log) remotely turning on climate control while the car is plugged in preheats the battery. This has worked for me with the recent cooler weather we've been having. I'm not certain, but I may have left the car in ”range mode” and it still worked.
  8. jerry33
    Texas
    It does, but it works slower--sometimes much slower. My wish is that range mode would be disabled whenever the car is plugged in.
  9. rapoport3a
    rapoport3a Member
    Ontario
    I've found that preheating the cabin to 20° (car plugged in but not charging) does almost nothing for the battery. Also, in the cold but not very cold weather, the cabin reaches that fairly quickly and the preheating turns itself off long before 30 minutes, definitely leaving the battery too cold.
    In preheating the cabin for battery purposes, to keep the process from shutting off too soon, should the fan be set low?
    I'll consider 26° but assume any cabin preheating is superfluous if I can arrange that the car charge its last bit just before driving off.
  10. Cottonwood
    Colorado
    Stevezzzz remembered my tricks well.
    By finishing the charge within an hour of departure, and preheating the cabin to 80˚F, 26˚C, during that last hour (you have to turn on the climate control multiple times), I have been able to drive almost 30 minutes with climate control off in the car and use only the seat heaters for the last 15 minutes with outside temps at 30˚F, -1˚C. Starting with a warm cabin and a warm battery heated on shore power are essential for maximizing range when it's cold.
    See Realistic Range Expectations in Crummy Winter Weather - Hypermiling in the Winter...Brrr for one of my winter adventures in the Model S last year.
  11. AmpedRealtor
    AmpedRealtor Well-Known Member
    Phoenix, AZ
    I wish the Tesla app would just let us input a "departure time" and adjust everything else appropriately. Pre-heat or pre-cool the car as needed and coordinate charging and whatever else so that the car is just ready to go by the time I set.
  12. jerry33
    Texas
    +1 That would be great.
  13. ghost640
    ghost640 Member
    Duluth, MN
    Would plugging into 110V help to warm the battery? (after full charge received). My 220 is only active between 11 PM and 7 AM, but I could plug into a regular outlet, wondering if that would help.
  14. jerry33
    Texas
    Yes, it would help. Actually, in cold weather warming the battery is just about all the 110V plug can do.
  15. AoneOne
    AoneOne Member
    Fox Chapel (Pittsburgh), PA
    Visible Tesla has a scheduler that might be able to do that.
  16. mibaro2
    mibaro2 Member
    Georgetown, ON
    The problem with Visible Tesla (and correct me if I am wrong) is that the program has to be running to do that. You can't set it, and turn off your computer.
    AoneOne , +1. Wish the app had the same feature.
  17. David99
    David99 Active Member
    Brea, Orange County
    At a public meeting in Europe with Elon, someone suggested that and Elon nodded and he said 'I agree'.
  18. ghost640
    ghost640 Member
    Duluth, MN
    Thanks Jerry, that's all I'd want it to do. Like the oil heater in my '82 Mustang...
  19. David99
    Brea, Orange County
    Reading through various discussions it seems there doesn't seem to be a way to heat the battery on user demand to a normal level.
  20. rdrcrmatt
    rdrcrmatt Member
    Milwaukee
    THIS!!
