Note: This feature currently requires accessing the site using the built-in Safari browser.
im not sure if it is either, but if it can be done with the drivers door, why couldnt it be done for all 4?I wasn't aware that was possible for any door on a Model 3.
i think it is possible...unless i read it wrong. i know it was rolled out with a SW update in response to frozen door handles. i have a model 3 so i never paid attention if the Y has that too, considering its nearly the same carI'm saying that I didn't know it was possible with the driver door. It's not possible on my Model Y.
In the Tesla app across the middle there should be a line of shortcut buttons. Tap and on hold one of the shortcuts and it gives you various options you can drag and drop to replace those buttons and change the order. One of the options should be a driver door release shortcut.I'm saying that I didn't know it was possible with the driver door. It's not possible on my Model Y.
So im guessing there is no third party support for this feature?Querying the internet finds this: Tesla Releases App Update To Fix Frozen Door Handle Issue
"The [app] update comes as version 4.14.0 and requires the vehicle's software to be updated to version 2022.36 or later."
@tackleberry23 As to the possibility for opening one or more of the other three doors, you'd probably have to petition Tesla to add that functionality.
Not that I'm aware of. Just being curious... what's your intended usage? I can see being able to open the driver's door (if stuck) could be useful but why bother with the passenger side rear door (for example)? Opening the door for somebody you're picking up without having to get out of the driver's seat? Might be good to have this in a pouring rainstorm I guess.So im guessing there is no third party support for this feature?
tons of possibilities.Not that I'm aware of. Just being curious... what's your intended usage? I can see being able to open the driver's door (if stuck) could be useful but why bother with the passenger side rear door (for example)? Opening the door for somebody you're picking up without having to get out of the driver's seat? Might be good to have this in a pouring rainstorm I guess.
that requires you to add a wiring harness under the console for them to work if i recall right?S3XY buttons
Yeah 2 minsthat requires you to add a wiring harness under the console for them to work if i recall right?
i was just checking those out again, $240+! app was $20 LOLYeah 2 mins
i like the idea of the buttons but the app does more. the buttons are grossly over priced unfortunately.you asked the question I gave an answer. The buttons obviously do more beyond pop open the doors
