Remove center console on 2017 Model S
Discussion in 'Model S: Interior & Exterior' started by John41, Dec 16, 2018.
  1. John41
    John41 Member
    Bay Area
    So I have a Sep 2017 build model S. A credit card fell behind the center console (note: do not leave a credit card on top of the center console sliding door), and I’m trying to see how hard it would be to remove the center console to retrieve it.
    I checked the thread and the instructions at Has anyone figured out how to remove the Premium Center Console?, however the console looks different on my 2017, where the console came standard. The side trim pieces are 1 single piece covering both the side of the center console and of the armrest (see photo), so the part about removing the side trim doesn’t seem to apply directly.
    Did anybody successfully remove the center console on one of these later builds?
  2. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    In the meantime just call the credit card company and report it lost, they'll cancel old one and send new one
  3. David29
    David29 Supporting Member
    DEDHAM, MA
    I have the older optional center console, so I have also lost things into its innards. But I would caution you to first be absolutely sure that the card is not where you can get it. In the older consoles, at least, thin objects can become lodged under the rotating door (door that covers the area where the USB plugs are), or far forward in the space where the cupholders are. You are probably correct, but do as thorough a search as you can (if you haven't already), using flashlight, positioning the doors every way you can, removing the cupholders, etc.
  4. akraut
    akraut Member
    San Mateo, CA US
    I've had that happen a few times. The first time I asked the service center and they found it for me. Took them about 5mins. The second, I did it myself. If you pop one or both of the side trim pieces off, you can see up into the supporting mechanism behind the door; the part up under the touch screen. That's where my cards were hanging out. I've only ever had to remove one of the side-trim pieces when I've lost stuff in there.
  5. John41
    John41 Member
    Bay Area
    Was this on the older, optional console, or the newer one with the 1 piece side-trim going all the way to the armrest? If so, how much of the trim did you remove? It looks like the seats would prevent me from popping it out entirely.
  6. akraut
    akraut Member
    San Mateo, CA US
    Mine's a MY2017, so it's one big piece down each side. If you slide the seat allllll the way back, you can do it. Though, I haven't had to actually remove it. Just pop it open and I could usually see the card and grab it.
  7. Jimmy 1
    Jimmy 1 Member
    Sarasota, FL
    Pop your Cubby slot out and you should be able to get back there.
  8. John41
    John41 Member
    Bay Area
    Worth a try. Any hint on how to remove the cubby? cubby removal - anyone know how? Says to pull down and out, but I’d like some second opinion if possible before I break something :)
  9. akraut
    akraut Member
    San Mateo, CA US
    Down and out, pretty hard. You probably won't break anything. ;) If you're afraid to try, DM me and we can meetup somewhere and work on it together. I have some trim-panel pry tools that we can use to avoid marring the finish.
  10. John41
    John41 Member
    Bay Area
    Thanks for the offer. I did manage to get the cubby out. I could get a glimpse of the credit card, but it’s still unreachable. Not worth the effort to try further to retrieve it. At least I established that it won’t hurt anything where it it located. On the bright side, I did manage to retrieve an old gym card that apparently made its way there the same way.
  11. Jimmy 1
    Jimmy 1 Member
    Sarasota, FL
    I have used a piece of flexible wire with a double stick tape on the tip it to get items. Glad you found the gym card!
  12. OFFXON
    OFFXON New Member
    Austin, TX
    I lost my ID on the sliding top. Popping out the cubby worked to find it. Thank you!
  13. bons
    bons Bonifus
    Hong Kong
    Thank god for this club this just happened to me...
  14. iCharge
    iCharge Member
    New England
    hey
    I just lost my work badge cum parking cum prox card [ all in one]
    I tried to get the cubby out but it is bending and not popping down. also there is not much space beneath the cubby to give it a push
    can you kindly message me, on where / how to push
    mine is a 18 MS
  15. iCharge
    iCharge Member
    New England
    can you kindly let me know where / how hard to push
  16. bons
    bons Bonifus
    Hong Kong
    So I stuck my hand in the cubby towards the left and push down w my fingers then moved to right and pushed down feeling where it gave way. Use some force w your palm as well. Eventually it’ll pop down!
  17. jgatl
    jgatl Member
    @John41, I installed the full sides, center console et al in my 2013. Start at the front top of the panel and work back toward the armrest. There are no screws holding these panels into the sides. Once you get the left and right panel pulled away the cubby has 4 u-clips that just snap under the touch screen, 2 near the front and 2 near the rear. Just push down at the front and then and then at the rear, and they cubby will pop off. Note that I have seen some cubbies with only 2 clips at the front and the rear has tabs.
  18. bons
    bons Bonifus
    Hong Kong
    Mine looks more like a tray, 2017 MS
  19. jgatl
    jgatl Member
    Unsure of the different configurations, but Tesla's EPC shows this illustrated with 4 clips. I've seen several with 2 clips and tabs on eBay.
    Although there are 2 part numbers, this site shows the 1018893 part as having 4 clips. Perhaps 1018893 is for RHD and 1045057 is for LHD?
  20. Kurtbe
    Kurtbe Member
    Ghent/Belgium
