Removing BOTH rear wheels at the same time?
Discussion in 'Roadster 2008-2012' started by smorgasbord, Sep 3, 2019.
  1. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    OK, so we all know that lifting a Roadster by both rear jack points is a bad idea:
    So, how can one remove both rear wheels at the same time?
    I was thinking something like this: Screen Shot 2019-09-03 at 2.12.44 PM.png
    How fancy do I need to be with that wood block?
    Any other ideas?
  2. smorgasbord
    SF Bay Area
    One potential concern is that I assume the brake rotor is held on tightly by the wheel itself. Yes, there a bolt or two holding the rotor, but I don't think the rotor was designed to support the vehicle's weight that way.
    So I assume this means I'd need to find a way to support via the control arms....
  3. im4uttx
    im4uttx Supporting Member
    Spicewood, TX
    Slight correction....there are not any rear jack points, only front and side jack points... :)
    The side lift points lift front and rear on the side of attack.
    So, if you want to take both rear wheels off at the same time, you would have to access the rear "lift" points:
  4. smorgasbord
    SF Bay Area
    OK, so I remembered that I had an old front wheel with some damage that I've been meaning to fix/give away. So this was my solution:
  5. Timothy
    Timothy Driving on Sunshine
    BTW, the top photo i NOT a Roadser!
  6. Tex EV
    Tex EV Member
    Houston, TX
    Did this when replacing the rear toe links. The front wheels were securely chocked. IMG_6733.jpg
