Removing gen 2 hpwc
Discussion in 'Supercharging & Charging Infrastructure' started by bmms8, Sep 16, 2020.
  1. bmms8
    bmms8 Member
    I’m thinking of relocating my gen 2 hpwc to a different residence. Can my electrician simply change current setup over to a nema 1450?
  2. Watts_Up
    Watts_Up Active Member
    In a galaxy far, far away
    #2 Watts_Up, Sep 16, 2020
    It depend if the Neutral was installed.
    If there is no Neutral, may be just replace the Powerwall with a connection box to protect the wires.
    To have a legal NEMA 14 50 require adding a Neutral, and may be a new 50 A circuit breaker.
    Adding a new wire in a conduit is not easy, unless it is very short with not too many curves.
    So it would be simpler to put connection box and put back a new Powerwall when needed.
  3. bmms8
    bmms8 Member
    Thank you for the insight!
    I will have to confirm if a ground is there.
  4. jmaddr
    jmaddr Member
    Florida
    If it doesn't have a neutral (they both need ground) you could put in a 6-50 instead. The 6-50 does not require a neutral wire.
  5. bmms8
    bmms8 Member
    sorry neutral *
    Thanks folks!
  6. arcus
    arcus Active Member
    Denton, TX
    Also, depending on your current braker, make sure to adjust the settings inside HPWC to match the new setup (in case it is different amperage).
  7. Rocky_H
    Rocky_H Well-Known Member
    Boise, ID
    @bmms8 You're asking if you can put in a 14-50, but have never once mentioned how many amps your circuit is for you wall connector, so it's impossible for any of us to answer that question yet.
    The answer is certainly "yes" for the more generic question of "Can I replace my wall connector with an outlet?" Always. But these questions of what kind of wire and circuit breaker will have to determine which kind of outlet. So more information please? What's the breaker and wire gauge/type in this?
  8. bmms8
    bmms8 Member
    Thanks for the feedback guys!
    It’s a 60 amp breaker with 6 gauge wiring.
    if no neutral I’ll do the 6-50. It was a lot of labor as the panel is 150 ft from hpwc
  9. mociaf9
    mociaf9 Active Member
    Then you'll also need to change the breaker to a 50A one.
