Also I would like to add, so far ive had three rattles, the phone tray in the center console, the seatbelt tensioner on the passenger side, and one from my passenger side door panel. the phone tray one seems like it just needs some sticky felt on it to make it snug. the one on my passenger door was from when the service center removed the panel and put it back on, they fixed it by taking it off a second time and replacing the clips as once the panel is removed its not a snug fit once you reapply it.. and the third one with the seatbelt tensioner I fixed by holding the button down in the second middle position and slamming it down to the lowest position kind of roughly so its locked down tight (that plastic that moves up and down on the tensioner is what rattles so slamming it down kind of wedges it down there, will most likely probably reoccur once somebody sits in it and uses the seatbelt but it felt good at the time) and that's it.
