Weathergeek
Okay, the OEM sub is rated at 1 OHM and the OEM amp puts out 560 watts but 80 watts to the sub. How did you get the SoundQubed HDS2.108 sub to work if it is rated RMS at 600 watts and is a dual 4 OHM speaker. It seems as if this sub wouldn't match up very well or at all.While you are in there drop in the SoundQubed HDS2.108, you can get this sub for about $100, I've had it in my car for two years now and after the initial break in, it has been awesome, you will have to drill new screw holes, but beyond that its a drop in install, the OEM sub is a TPOS and weighs about 10 ounces vs the SQ which is 100 ounces. Note I also have the LightHarmonic AMP too, so I am driving ~ 600 watts to this sub.
Power Band - 600 Watts - SoundQubed
LightHarmonic AMP Specs
