Removing the Model 3's center console?
Discussion in 'Model 3: Interior & Exterior' started by RDaneel, Mar 28, 2018.
  1. RDaneel
    RDaneel Member
    New Jersey
    I'd really like to have a matte PPF installed on my Mode 3's center console. The gloss black will drive me nuts. As the PPF products require a wet install, I'm a bit wary of having it installed in the interior - no idea where excess water will end up and this car is, essentially, a 4000 pound brick of electronics!
    Does anyone have any resources that would help me disassemble the center console so the gloss pieces could be wrapped outside the car? I don't see any hits on google, youtube, or reddit, but I am guessing that some knowledge exists somewhere!
    Thanks in advance...
  2. Jimmy 1
    Jimmy 1 Member
    Sarasota, FL
    I think....you may be over thinking this. You will be fine, just wrap it.
  3. RDaneel
    RDaneel Member
    New Jersey
    Thanks, but when my very experienced installer is skeptical of wrapping it, I take notice.
  4. doubleohwhat
    doubleohwhat Member
    Alabama
    I feel like a better wrap could be done with the console panels removed. So I'd like to know how to remove the panels as well.
  5. chojn1
    chojn1 Member
    Sugar Land
    You are as OCD as me.
    This may help you get started:
    I am still looking for a way to remove the wood dash.
  6. RDaneel
    RDaneel Member
    New Jersey
    Ah, thank you! Very helpful!
  7. garrity
    garrity Member
    Good written explanation of disassembly by member Rdaneel
  8. barjohn
    barjohn Member
    Riverside, CA
    having wrapped it myself using RPM Tesla's 3M clear PPF I can tell you that you won't put enough water on it to cause any problems (make sure your water bottle is a fine mist sprayer). I did it and it was a first time for me. It took a while and I didn't get it perfect but now that I have it, I have decided to go with one of the other materials like the bruised metal or matte finishes as it is still to hard to keep looking nice. You touch it much too often and finger prints just stand out. The others are a dry install and you need to really take your time on alignment as you are taking a 2 dimensional object and fitting it onto a 3 dimensional surface.
  9. slade037
    slade037 Member
    Clifton, VA
    So I followed this video to help me wrap my interior with satin black vinyl. I also removed the top panel for the phones. When trying to put the screw back, it fell down the left opening where the hinge is. I lost a screw into the abyss.
    I tried using a long magnetic poll to get in there but I came up empty. I removed as many screws as I could see to maybe remove the whole bin but it doesn't seem like it would budge.
    Does anyone know how to get in there to retrieve the screw?
    Thanks!
  10. RDaneel
    RDaneel Member
    New Jersey
    Slade, I had the same issue (a different screw fell into that same abyss). Unfortunately, at the bottom of that space is a portal to another dimension through which that screw has traveled. Assuming it wasn't ripped apart by the singularity's tidal forces, it is now on Earth Prime, holding together your evil double's Tesla.
    Seriously, though, I don't know of a way to disassemble that area. You'd have to pull off the carpeted sides of the console and remove a whole lot of parts to open up that area. I'd probably just take a screw from one of the aluminum trim rails (which have about six screws per side, and I think the screws are the same) and use it there. Sorry I don't have a better answer!
  11. jelloslug
    jelloslug Active Member
    Greenville, SC
    The screw is actually in somebody else car now.
    • Funny x 2
  12. chojn1
    chojn1 Member
    Sugar Land
  13. barjohn
    barjohn Member
    Riverside, CA
    Well it used to be common when you took something apart and put it back together you came up with spare parts. :) I am surprised you can't find it with the side off. The carpeted panel also pops off. I saw a video somewhere, I can't recall where of this panel being removed. You just get your fingers under the front edge and pull. That should give you access to the area. IMG_1930.JPG
  14. slade037
    slade037 Member
    Clifton, VA
    Luckily it doesn't rattle down there or slide around making noise. That would get me all kinds of crazy. I replaced that screw with one inside the cubby where your phone charger goes into the USB. Same exact screw. The camera isn't a bad idea.
  15. slade037
    slade037 Member
    Clifton, VA
    Are you saying I can pull from the red arrows to open up the carpeted panel? I have plastic pry tools that I can use. I already have the side of the center console off noted in the red. The piece in between the two does not seem to budge.
  16. barjohn
    barjohn Member
    Riverside, CA
    Yes, here is one of the videos I saw on access to the cabin filter and they show removing this on passenger side. Another video looking for air filter showed driver's side removed.
  17. slade037
    slade037 Member
    Clifton, VA
    This is fantastic! I will try this soon. THANK YOU!
  18. slade037
    slade037 Member
    Clifton, VA
    You weren't kidding. I used the videos and opened up the driver side panel and could not find the screw. I'll open both sides this weekend and send out the search party one more time.
  19. RDaneel
    RDaneel Member
    New Jersey
    I'd love to see pics if you figure out how to open up that area! I'm not saying I'll go fishing for my lost screw, but it would be nice to know how...
  20. jsmay311
    jsmay311 Active Member
    Chicago suburbs
    That video is no longer available.
    Here's one showing removal of the trim, although it's self-described by the uploader as "a sh***y video". :)
