but whole blog it's very pro carbon, but non the less CSP numbers are real and tragic
I still want to try lots of different "concentrated solar power" ideas, such as beaming concentrated sunlight into a cement kiln during the day and using similar beams of light emitting electronics at all other non-sunny times of day, using vast amounts of electric generation, but that sounds super inefficient, but I still don't know a better way to supply clean energy for cement kilns. I'd love to see the numbers to see if the amount of pollution saved from not using coal for cement kilns would be enough to offset the amount of pollution used to install the energy storage and energy delivery at dark times of day, as well as the concentrated solar during sunny times of day.
But, CSP for electricity generation in general sounded like a good idea and ended up having lots of problems. Thus, even if research were to start on CSP and/or electrical heating for cement kilns, I have pretty low hopes. I'd still like to know.
CSP is certainly a lot less tragic than Chernobyl or Fukushima....
I find it instructive both happened at a time that those societies were already or becoming increasingly closed, less free speech, cultures that didn't value truth, and things like that. In what used to be the First World (USA, Europe), nuclear power has had successes. We actually use it in a clean way. But, it is true that nuclear power has a high cost of culture, regulation, engineering and maintenance that doesn't exist with solar photo-voltaic panels, so we concede that in a world in which we are trying to decimate the culture of the First World (for better or for worse, whether we are in favor of it or not), a better bet is solar PV power, which doesn't require precise ethics, regulation and maintenance. And don't get started about "nuclear waste": there's basically no such thing -- properly managed nuclear fuel can be recycled. However, that shares much of the difficulties of overall nuclear power, and doesn't escape what I said about nuclear power in general.
However, I'm tired of the lie that nuclear power is intrinsically bad. With proper culture, engineering, design, regulation, care, and maintenance, nuclear power only has three problems as far as I'm concerned: (1) it turns material into heat, thus causing net raise in planetary temperature; (2) it has significant costs; (3) it is not resilient in the face of any downfall of the predicate requirements I listed. #3 tends to be the example that those who want to remove proper culture and care from the society tout as the main problem with nuclear power, so they are self-consistent: because they want to destroy the culture that can support nuclear power, they say that nuclear power is thus unsafe in their vision of the future world. In the vision of the future world that wants to maintain the culture and care that can safely support nuclear power, we say that nuclear power in and of itself is and was fairly good (although better alternatives now newly exist). It amounts to a culture clash. One could even say the conclusions are based upon the goals of the conflicting visions, and that within each vision, their opinion of nuclear power is correct.
I think there's also more to do with some countries attempting to hurt other countries by removing their use of installed nuclear power since it will make the other countries weaker, so they set up protests in the target countries. But that is synergistic with the culture issue.
All of this stuff can be avoided by adopting solar PV + storage, though, so we're going that direction. At least in that we can all agree.
I love your explanation, and I am not quite sure I fully understand it. Can you give a more detailed explanation? For example: What is a "low voltage distribution circuit".... are there separate circuits within the power distribution grid? I tend to imagine the grid as a large river with lots of small tributaries, each of which can flow either way (export or import), but maybe my analogy is too simplistic?
Although many use these terms incorrectly, because it seems to be all relative to what you are used to, they are defined by IEEE for equipment designations as"
LV - 600V or less
MV 601V-69,000V ( Changed a few years ago)
HV - 69,001V-230,000V
EHV 230,001V-800,000V
UHV >800,000
I feel if everyone used these properly a lot of confusion could be avoided. I get a lot of calls for service work and repairs on "High voltage" breakers, when asked if we work on HV breakers my answer is always, some of them, but only up to 115kV, the answer is usually, "I was talking about 4160V" or something like that.
To partially answer your question, Low Voltage is the A/C that travels through your home for electric wall sockets and other hard wired appliances. Interestingly, computational and other kinds of electronics like audiovisual tend to consider that "high voltage", so anybody coming from the audio or computer world may be mistaken thinking that low voltage means something else in power distribution.
Here's some explanations of why they use various voltages in energy transmission; Google around and you can find much more info:
The Physics of Everyday Stuff - Transmission Lines
SolarPro Magazine
http://www.epu.edu.vn/UpLoadFiles/DS05B_V1.pdf
