@ecrsail what charger are you using to charge the lead acid battery? thanks
Thank you!
Does the 12V from Tesla car go into the solar panel input of the charger?
Nice looking but nothing like that in the USA.I cannot see photos of previous post, but I bought this: TAWA Q36
Thanks for this set of observations. You have expressed a lot of my worries in this report.So bringing this topic back to life. Instead of Dometic CFX-40 or 35, I actually went with the 28. The 28 is a lot smaller, but I got it for a few reasons.
Here is why
#1 It is slimmer than the 40, which was almost rubbing the seats based on what I saw in the pictures. With the way I drive, it would not be difficult for me to start rocking it back and forth. I also was unsure of the fit if I were to put a case on it, that's why I opted for the 28 with a cover to prevent rubbing.
#2 I use my car as a dog carrier, having the unit inside the car would actually prevent my dog from enjoying the car. Therefore I will leave this in the trunk most of the time, the 40 is too big for the trunk where the 28 is nearly perfect.
#3 With the trunk cover in the low flat position (not the high flat position), the 28 can sit perfectly flat in the trunk with the rear sill act as a cradle. The 40 might fit inside, but I don't think you will be able to open the lid without tilting it. The 28 can open its lid with slight rubbing at the very top, but you shouldn't have to tilt it. The unit will fit without the trunk cover in place, but the unit will be tilted since the floor isn't flat and I would rather have it flat. Yes it sucks to lose the trunk space, but it is what it is. Also the trunk cover will hit the fridge in the open position since it is tilted into the trunk space. The fridge will wedge it against the seats.
#4 As an added bonus, I was able to squeeze a collapsible bin right next to the fridge in the trunk. It will come in handy in organizing the trunk.
Cons of the 28
#1 The unit sits maybe 2" too low as an armrest, I think the 40" is probably the ideal height if you want to use it as an armrest.
#2 It looks small for Costco frozen food run
#3 The unit is lighter, I can see it moving under heavy braking if you were to put this inside the car. I would probably get some sort of safety strap and tie it to the seat post
I will start running this this week, let's see the performance on it. It's about 90F here
Yes. See pictures below.
I use the CUZEC Heavy-Duty 15A Male Plug to feed 12V power from the Model X rear power adapter. Make sure you pay attention to the polarity (red is positive, black is negative). These are the two terminals on the left under the solar panel icon in the image. When the vehicle is supplying 12V accessory power, the sun is shining. When the vehicle is not, the sun goes away. Cute.
I used 16 gauge wire (red and black) that like any good electrical engineer I already had and then crimped & soldered eyelet terminals to connect the battery to the charge controller. You can find the wire and eyelet terminals at a hardware store if you need them. Again polarity matters.
I use the NOCO GC018 12V Adapter Plug Socket with Eyelet Terminal to provide power to the Dometic. This adapter is connected directly to the battery rather than the load terminals (light bulb icon) on the controller. Polarity matters here too.
Everything is securely connected and fused. As noted previously, I'm using a commonly available sealed 18 Ah lead acid battery to ensure 24+ hours of refrigeration if the vehicle sits powered off. The battery sits in a battery box in the under trunk, and some velcro holds the charge controller either in the under trunk or above the removable floor if I'm on a road trip and want to be able to easily monitor the charging state and battery voltage.
Hope this helps.
Did you get the Dometic insulated cover for the 28 and if so how does it fit between the seats?
Thanks for the test fit. Did you also try fitting it between the 2nd row seats?I got the cover on. Everything fits fine. It fits between the seat and on one side of the trunk.
Can you keep the 12V outlets on when the car is off?The only problem I am still trying to figure out is how to make the rear 12v a permanent plug.
I have a 35 with the insulation and it fits fine in my 6 seat X. Just got back from a 5 day trip and it worked excellent. Just plugged it into the rear aux (cig) plug. It cools pretty darn quick.Thanks for the test fit. Did you also try fitting it between the 2nd row seats?
I am worried about the 35 crushing the seat sides. That was one reason to go with the 28 and cover.I have a 35 with the insulation and it fits fine in my 6 seat X. Just got back from a 5 day trip and it worked excellent. Just plugged it into the rear aux (cig) plug. It cools pretty darn quick.
The 28 fits with a palm size gap on both sides even with the cover. You can’t sit it in the trunk if it is any widerThanks for the test fit. Did you also try fitting it between the 2nd row seats?
So you don't think there is an issue with the cover and the 35 crushing the seat sides? That's over 2" more than the 28.
