Repair faulty windscreen moulding on Model 3 using wiper blade rubber
Chung Gumin
6
-1
Seoul, South Korea
Photo 1: If you look at the front glass molding of Model 3, it's floating like the picture below. Almost all models3 are defective in this state.
Photo 2: By the way, this defect can be fixed as original.
Photo 3: Use the old wiper blade rubber.
Photo 4: The blade rubber tip is in a T-shaped You can cut it and use it as a repair material. Note that you can fix it by lightly applying a strong bond at the end.
The YouTube video below is in Korean. However, even if you don't know Korean, anyone can follow along.
from. Korean DIY Man.... Solomon.
  • Disagree
Reactions: WarpedOne
