Can we agree now not to apply power to any more systems without investigating their condition first?
woah now..
I take FULL responsibility for the areas highlighted in RED
the rest the salt water took care of on its own :biggrin:
But what we can't guarantee is that it couldn't have been cleaned before voltage was applied.woah now..
Cleaning can do wonders in these cases if no power goes through it. That white might come off with some work, those areas you highlighted are probably toast.
Sure a professional repair is to simply remove and replace all those modules, but that doesn't mean that they can't be cleaned with some success, assuming power is not applied.
You don't need to man. That's just rust from the transistors.
But you do need to take full responsibility for ignoring numerous posts admonishing you to not connect power, and drunkenly attaching power after scratching your head for a long time.
Are you going to try to inspect/clean the chargers first? or just plug in and see what happens?Just wait and see what happens when I try to charge the car.
If the former, I have a ton of respect for the work you are doing to learn and repair.
If the latter, I'm starting to think that repair isn't really the goal...
Ingineer he's already let out the magick blue smoke that makes electronics work. And he said there was a *SNAP*, which was probably the pyro.
mmmm ... I can smell it from here
fwiw I doubt that brown stained damage was done by you, that is more likely from prolonged damp whilst the unit was powered/residual charge.
Does seem to have been wet for some time as it looks as though it is concoated as wk says (maybe not very well) but the moisture has got under the coating.
time to get yourself some PCB cleaner and some DI water and a natural fibre brush ... let's see what's left in there
Almost certianly history but I have seen some stuff as bad as that resurrected in my time.
otoh go and find something that's not in quite such a mess
You interpret me completely wrong.If you arent already excited enough....... Stick around, I may have some more bad news for you!
