I had a bit of an off on the track and ended up with a bit of a loose ball joint on my MPP Corkscrew FUCAs.
While the ball joint is labeled DELPHI TJ21G, this didn't really help when looking it up. So I took some quick measurements of the ball joint (43mm diameter, 64mm high, 18mm pinch bolt) and found the actual Delphi Part- TC2431. This is off a 2010-2017 Nissan Leaf. You can see the specs here:
I bought a ball joint for a Leaf off Amazon for about $20. Popped it out and in with a cheap harbor freight ball joint kit with no issues.
The part I got was a Centric part, and it has serrations on the diameter unlike the Delphi part. While it works, I would highly suggest finding a part with a smooth bore like the original Delphi part.
Hope this helps someone in the future.
