Replace 12 volt battery
Discussion in 'Model 3: Battery & Charging' started by hcdavis3, Apr 22, 2019.
  1. hcdavis3
    hcdavis3 HCD3
    I didn’t see this service bulletin. Took my car to service at Tesla Dedham Ma. They replaced my 12 volt battery at 1700 miles on my 3. I’m curious as to what the issue was with the original battery. They didn’t replace it with a lithium ion battery. I was hoping. Anyone else seen this. Thanks.
  2. evM3Sekar
    evM3Sekar Member
    Cincinnati, OH
    Did you take it in for this service? Or was it for something else? No, I haven't seen this service bulletin.
  3. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    There are battery failires with any batteries. Of course they wouldn't replace with a lithium ion battery, it isn't a good cost/performace trade-off. If it was, they'd have one in there to begin with.
  4. hcdavis3
    hcdavis3 HCD3
    The car was built July of last year. I did take it to Dedham MA service center and the advisor said there was a bulletin on the battery. Must be build date specific. Replacement was lead acid.
  5. hcdavis3
    hcdavis3 HCD3
    Thanks Ed. I did ask for a Li ion battery...service advisor laughed.
  6. jkoya
    jkoya NA2 NSX
    Northern CA
    Are there other makers of Lithium 12V batteries other than Ohmmu ?
  7. hcdavis3
    hcdavis3 HCD3
    Morning j. I think I’ve see a couple but can’t remember their names. Google 12 Volt lithium batteries and you’ll come up with a bunch. I’ve heard of issues with the lithium batteries installed in a model 3. You’d think a 12 volt car battery would be the same regardless of the kind, but somehow the 12 volt lithium batteries installed in a 3 cause error messages. What I’m most curious about is there a savings when driving due to the weight reduction.
  8. mike123abc
    mike123abc Member
    Norman, OK
    My car was made in 8/2018 and my 12v battery failed and had to be replaced.
    The battery is an odd size, it is pretty small for a car battery. It also has a gas vent on the driver's side that hooks up to an exhaust tube.
    Lead acid batteries do specific things very well. Maybe the model Y will be able to finally get rid of it, it will be interesting to see if they can get a replacement worked out.
  9. Wennfred
    Wennfred Supporting Member
    San Diego
    Purchased a Ohmmu lithium battery so that at 1700 miles I won’t have to deal with a failed lead acid one. Battery should arrive tomorrow Wednesday, shipped from Ohmmu at a lower cost then on Amazon. Main reason I am going this route is the weight, 11.5 Lbs the Lead acid one is 28 Lbs. Every bit counts.
    Fred
  10. hcdavis3
    hcdavis3 HCD3
    Let us know how it works. There’s gotta be some energy savings due to weight loss.
  11. LGA737
    LGA737 Member
    NJ
    I don’t think your Tesla is gonna like that battery. Tesla charges and discharges that battery based on a very specific battery specification. Have you been having problems with the OEM battery or is it just for the weight savings? 11.5/3900 = 0.3% reduction in weight. You I don’t think you’ll see a measurable improvement in anything with that small a reduction. That said I’m interested to hear how it goes.
    • Informative x 2
  12. LGA737
    LGA737 Member
    NJ
    My wife’s LR is a year and a half old with 30,000 miles on it still on original 12v battery BTW. Mine has 5,000 also on original battery.
  13. hcdavis3
    hcdavis3 HCD3
    What’s the build date of your car? Mine was built July of 2018. The service bulletin may be for specific build dates.
  14. LGA737
    LGA737 Member
    NJ
    12/17 and 11/18
  15. derotam
    derotam Member
    Oak Hill, VA
    There are issues with using Li-Ion for the 12v, one of which being a temperature issue. To use a Li-Ion 12 battery you would need temperature management(cooling/heating) to keep the battery in the correct operating range. Without that and in a cold environment and the 12v Li-Ion battery wouldn't work well.
    • Informative x 2
  16. Wennfred
    San Diego
    Got the Ohmmu Lithium Battery in today, the swap took around 5 minutes, what a major difference in weight, I mean pulling the lead acid battery i had to lean against the fender to get the leverage to pull it out, almost weight as much as a normal ICE battery even for its small size. The Ohmmu is ultra lite at 11.5 Lbs and was the same fit as the OEM one. Everything came up inside, Nav station, sound system etc. took the ride around the neighborhood and no issues so far. Will drive it to work tonight and see how it goes.
    Fred
    • Helpful x 2
  17. evM3Sekar
    evM3Sekar Member
    Cincinnati, OH
    Couldn't find info from a quick search on these topics. Anything your research revealed?
    1. Does it void any of Tesla's original warranty?
    2. Ohmmu's BMS test and data?
    Sounds promising on paper - awesome indeed! Curious about what you find out.
  18. GPinzone
    GPinzone Member
    Ronkonkoma, NY
    If the new part causes damage or failure, then Tesla isn't responsible. If it doesn't then Tesla cannot claim the warranty is void. It's against the law for them to do so.
  19. Wennfred
    San Diego
    First work day out, night time drive 62 degrees and back home this morning on the Ohmmu Battery, round trip was 40 miles, no glitches, no error codes, all worked fine... sound system, Nav station, Wireless Phone Charger, Easy Entry Seats, horn, auto door, auto Frunk latch. The new battery is holding up well.
    Fred
  20. Wennfred
    San Diego
    Oh and the Rear view Camera comes on immediately on reverse now, with the old Lead Acid Battery the rear view camera screen would go black for 3 to 4 seconds before it turned on.
    Fred
