My lights keep flickering and my right headlight turns off every 10 min. where is the best place to buy replacement buts for MS? Thanks guys!
if you have the original HID xenon's, i replaced mine with these: https://www.amazon.com/gp/product/B076BWMW54/ref=od_aui_detailpages00?ie=UTF8&psc=1 if you have a newer MS with LED bulbs then you need something different.
Are these light bulbs appreciably brighter and/or whiter than the originals? My 2012 P85 headlights are fine but I want something brighter and whiter.
I don’t have these bulbs, but they are rated at 4800K, so will be a bit whiter than stock, which is 4300K. 6000K and above starts looking a little blue. They are also advertised for 50% brighter output which another member confirmed with n the other thread so you’re good to go.
If you want to look at replacement HID headlight bulbs, and want the most light output (lumens) stay around the stock temp (4300K) range, which would be 4300K - 6000K! If you want it whiter, you should go with 5000K! 6000K would be the highest you want to go, as you start getting the blue color in it!
hi guys, my hid d3s bulbs have failed on my Tesla model s, do you know if these bulbs put link here will work ? HID D3S Xenon Bulbs | D3S Bulb 4300K, 6000k, 8000k, & 10000k
According to these guys, the OSRAM "Nightbreaker" is the brightest of what they tested with some other off-brand options being slightly brighter. BulbFacts | Best Recommended HID/Xenon Headlight Kits
Replaced one bulb today as I have been having intermittent problems. Got the Philips X-tremevision gen2 and, frankly, can't see any useful difference between the new bulb (US passenger side - right side) and the 6 year old original bulb. Pictures below... green arrow marks the new bulb - if anything, the new bulb has a hot spot in the middle while the old bulb is more uniform. Cut-off is equally good. In the process, discovered a broken ground lug on the frame rail and fixed that - likely that was the source of my intermittent headlight problem... FWIW, I tried to change the bulb by removing the frunk tub. You can get your hand on it that way, but its too tight - ended up removing the wheel and wheel liners like others have posted. Having the frunk out did make that part easier.
