With the new crop of double-DIN navigation receivers being released early this year, I decided it was time to make the move to replace the Alpine IVA-NAV-10 in my Roadster 2.5. To say that I detested the Alpine would be an understatement as so much of it, in my view, was poorly designed. But other postings have berated the Alpine IVA-NAV-10 so I will not do so again here. I had three major improvements I sought with a replacement unit: (1) a real knob for volume control; (2) traffic information; and (3) speed sensitive volume. I managed to achieve the first two but not the third. In my view, having a lever like was on the Alpine on a radio for volume control is a an accident waiting to happen as it is difficult at best to find the control while driving. On the Roadster in particular, being able to raise and lower the radio’s volume is essential due to varying road noise at different speeds. I know that this means that the units with the largest screens are out, all of which forego a knob for volume in favor of a lever. But, for me, the volume knob was the most important. The two units I tried were the new JVC KW-NT500HDT, and the new Kenwood DNX-6990HD. Both units have all of the features of the Alpine including Bluetooth, HD Radio, Navigation and satellite radio. Unlike the Alpine, however, all of the features except for satellite radio are within the double-DIN unit and not add-on modules. Interestingly, the power draw of both the JVC and the Kenwood are substantially less than the Alpine even without all of the add-on units. The Alpine IVA-NAV-10 draws 4.35 milliamps with the ignition/unit off, and 2.18 amps with the unit on. The new JVC KW-NT500HDT draws 1.76 milliamps with the ignition/unit off, and 1.39 amps with the unit on. The new Kenwood draws 3.83 milliamps with the ignition/unit off, and 1.73 amps with the unit on. Thus, either the JVC or the Kenwood, even with the Bluetooth and HD radio modules built into the main unit, are substantially superior in power use as compared with the TESLA OEM Alpine. Neither the JVC nor the Kenwood appear to present power consumption issues in the Roadster. The initial install I did was the JVC KW-NT500HDT. Be forewarned. This unit will not be satisfactory in the Roadster because it requires a connection to the vehicle speed sensor. Even though the Tesla radio wiring harness connection has a wire for the vehicle speed sensor, for unknown reasons the JVC would not satisfactorily operate with the VSS. Rather, the JVC gave repeated VSS error messages. The JVC would satisfactorily read the VSS up to about five mph but thereafter give an error message. I went through JVC two firmware updates, and one change in the radio’s internal settings from “digital” to “analog” for the JVC VSS function, with the JVC techs who were amazingly helpful and responsive, in an effort to correct this issue. In the end, however, neither firmware update worked, and the change from digital to analog in the units’s internal settings did allow the speed sensor to work while the car was moving, but (somewhat humorously) showed speeds of approximately 500 mph while the Roadster was standing still, with the map jumping around like the car was flying. I finally gave up on the JVC after spending many hours trying to resolve this VSS issue. I should note, however, that even if the VSS had worked and not given the annoying error message every time the car started moving, I concluded that the JVC had too many other troublesome aspects to it that did not trouble me to leave it behind. The JVC lawyers have apparently gone overboard in making the new JVC unit a brick while driving. Rather than having a passenger adjust the radio, choose a song or work with the navigation, to use the unit it is necessary to pull to the shoulder of a road and run the risk of being mowed down. The grayed out screens in themselves should cause anyone looking at the JVC to think carefully about whether such a dumbed-down unit is desirable. I need to say a word of recommendation about the electronics dealer Crutchfield here. I purchased both navigation receivers from Crutchfield. After my experience with the JVC VSS issue, Crutchfield without any hesitation swapped that unit for the Kenwood DNX-6990HD. I could not have asked for better service or a more satisfactory experience from a retailer. I highly recommend Crutchfield for electronics as it is far better to purchase from a firm like Crutchfield that stands behind its products, than possibly save a few dollars. For the install of the new navigation receiver in the Roadster, the first choice is whether to remove all of the Alpine components including the two satellite radio modules, the Bluetooth module, and the HD radio modules. I opted to do so because I was looking to do this right. In retrospect, I probably could have left all of the extraneous modules in but that would be extra weight being hauled around and extra current being used. To remove all of the Alpine components, it is necessary to remove most of the front dash and the top of the dash. In a nutshell, start by removing the four small screws from beside and under the steering wheel. That releases the lower housing around the steering column. The molding around the radio pulls off. It is held there with four clips that will fall off and will need to be retrieved with a hook or other tool. The speedometer cowl is held on by clips and Velcro. The side panels (think of where the headlight control is and the like panel on the passenger side ) are held on with a combination of six screw and two clips each). Before taking off the side panels, take off the running boards which are held on by Velcro. The airbag panel has breakable plastic clips which will break. You should get four replacement plastic clips (get eight to be sure) from TESLA prior to starting the project. The top of the dash itself is held on by four screws. Here is a photo of the dash removed: You will need an Alpine radio removal tool unless the entire dash is being removed. It can be found on the web for less than $5. I am not sure if the removal tools that come with the Kenwood and other double-DIN units work with the Alpine but they may. The Alpine Bluetooth module is behind and to the left of the radio. In the well behind where the headlight switch are two Alpine satellite radio modules and an HD radio module. I never located the satellite radio antenna. I was told that it was probably behind the left headlamp. As it turns out, there is no need to replace it as, even though it was for Sirius and the Kenwood uses an XM tuner, the OEM satellite antenna works fine and has the same connector on it. In fact, in experimenting with placement of the antenna that came with the XM tuner, I concluded that wherever TESLA placed the satellite radio antenna works better for reception than just about any other location. The GPS antenna is not interchangeable between the Alpine and the Kenwood. I never found where TESLA put the OEM GPS antenna so I could not remove it, but I ended up putting the new GPS antenna under the speedometer cowl which works just fine. There is plenty of room under there for the GPS antenna like this. The Alpine back up camera will not work with any unit other than an Alpine as it is a proprietary camera that does not have a standard output. As the back-up camera for me was more of a distracting novelty rather than an essential element of the car’s system, I did not replace it. The USB cable in the Alpine unit is used for the HD radio module as well as for connections to USB devices which might be why the USB function appears to work so poorly on the Alpine. There is a USB cable with a male “A” USB connection on each end going from the Alpine navigation receiver to the HD radio module in the left well, and from there, a standard USB extension cable runs to the center console. I was able to use the existing USB extension cable to just reach the Kenwood but keep in mind that a new USB extension cable might be needed. Somewhere in the car TESLA put an amplifier for the speakers, and there is a subwoofer in the left rear wheel well. All of this works fine with the Kenwood. To wire up the Kenwood using the existing Alpine wiring harness, look at the diagram on the top of the Alpine navigation receiver itself after removal to identify the wires. The color coding on the TESLA harness is not Alpine standard color coding. Rather, the harness is an OEM TESLA harness made for the Alpine. I labeled each of the wires as I clipped them which is the prudent thing to do as once clipped, it is impossible to later match them up. The Kenwood has a wire for dimming screen illumination which the Alpine did not have. Such a wire is in the TESLA wiring harness but is not carried through to the connector for the Alpine. It is not essential to connect this up as the Kenwood can be set so that when the Garmin navigation system recognizes that nightfall has occurred, it dims the radio screen. Connecting up the illumination wire will dim the Kenwood screen anytime the headlights are on. Because I like to run the Roadster with the headlights on all of the time, I added a module with a photocell that senses when it is dark, and turns on power to a wire that runs to the Kenwood harness to dim the screen. To do this, I used a Directed Electronics 545T Nite-Lite System which is vast overkill for what I wanted it to do (turn on 12 volts when dark), but its $29 cost convinced me that I would spend almost as much in parts to design a circuit to satisfactorily do what this module was built to do which is turn on power when it is dark. The new Kenwood DNX-6990HD in my Roadster does everything the Alpine did, has the real volume knob, has a Garmin navigation system with traffic information which is far superior to the Alpine navigation system and allows for uploading of points of interest such as traffic enforcement cameras and charging stations. It does not have the speed sensitive volume although given the wide variation in Roadster ambient noise, I am not sure that if it did, it would be satisfactory. The Kenwood AM and FM radio itself appears to be somewhat less susceptible to the electrical noise generated by the TESLA. FM reception appears to be somewhat better, and AM stations with fairly strong signals are listenable which was not my experience with the Alpine. The one complaint I have is that the Kenwood screen in bright sunlight with the top down is not bright enough to be seen with polarized sunglasses on, even at its brightest setting, but I do not recall the Alpine being much better. The Garmin navigation system in the Kenwood is superb, and the Kenwood receiver has capabilities for Pandora, iHeart radio and the variety of other entertainment services being offered through smartphones. The Kenwood fits perfectly into the Roadster dash opening. Now, I need to list the Alpine on eBay.
Wow. Nice work. This is something I have been thinking of doing ever since I got the Roadster. The Alpine isn't great so I'm glad you did such good research into a replacement. Thanks.
Great write-up, thanks! On my car it's on the back of the instrument cluster (i.e. the analog speedometer).
Wonder if this would be an option. Sticking with Alpine might make the switch easier but you'd still have an Alpine. Alpine INE-S920HD Navigation receiver at Crutchfield.com
Thank for this write-up. I too hate the stock Alpine, but I'm not willing to part with the back-up camera. Bummer.
To interface w/ the backup camera you need the little box that comes with this camera kit. (HCE-C115) FYI: Amp is a royal pain to get to and is a 2 man job even for the rangers, so I'd advise against replacing it. The sirius antenna is behind the driver side head light. If it is legal in your local I'd recommend running the bypass on your radio. It will enable access to certain items while the car is in motion or in drive. (use responsibly) Oh, and one last thing: NICE job.
On my car there is also what appears to be a GPS antenna on the back of the instrument cluster (it is an approximate 1"x4" rectangle), but I was told by the TESLA techs that it is the GPS antenna for the car's monitoring system (the feature that tells the car at what current draw and when to charge based upon location among other things) and not for the navigation receiver. Therefore, I did not disturb that. I tried following the wire from it but was unable to discern where it went.
That is actually the GSM antenna. It connects to the VMS module under the dash. The GPS is in another location.
My memory is getting foggy but I could swear I saw the GPS antenna in front of the driver's side headlight when I was changing bulbs.
I had not seen that Alpine unit (looks like it is a very new model) when I was looking for a replacement so it certainly looks like an option that might be worth considering. Below is the wiring diagram from the OEM Alpine to compare with the wiring harness diagram whenenver the installation manual for that new Alpine is made available. If the radio connection wiring harness is identical, and if it uses the same the satellite radio module, that certainly would make for an easier install. Even so, I found so many things with the OEM Alpine I was unhappy with that I am happy that I did the work to install the Kenwood. Unless Alpine has vastly improved its product, the Kenwood has a vastly superior navigation system and much more user-friendly radio receiver controls.
Regarding the Alpine INE-S920HD... After having the 910 unit replaced three times, Alpine sent a 920 to my Tesla shop as a replacement. Pro - The Nav system comes up really fast, faster than the 910. Con - There was no XM input on the menu. Even though the service guys promised that it was connected. Nothing would make it come up, a fact that was driven home during the XM free promotion they've run on and off the past few months. Con2 - There was no installation guide or manual sent, and after 2 hours on hold for tech support at Alpine, the service guys gave up. Super Con3 - It's still just like the Alpine 910. Bad user interface, bad buttons, etc... Everything I hated about the 910 is still present in the 920... It was just a distraction waiting to cause an accident And I agree, Crutchfield was great. I purchased a refurb DNX690HD, for a few hundred discount. They were very helpful. - - - Updated - - - About the camera, I got it working with the existing one in my Roadster 2.5. I fabricated a power supply adapter to run the camera. I epoxied a LM7805 regulator into a small plastic case. (see the image of the case before I filled it with epoxy). I had two choices... slap this together fast, or spend the time fabricating a PCB and case. I choose the fast solution. I wired the old Alpine on my bench and reverse engineered the 6 pin connector that the Alpine camera connector. It appears to usee [video, gnd, NC, +5, gnd, shield], starting with yellow on one side. They probably use a floating ground to eliminate ignition noise, not an issue with a Tesla. So I plugged the camera cable into the 5 pins (spaced weird because the connection is not on 0.1" spacing). The video to the new Kenwood is just an RCA plug, and I connected the red power to switched (ignition) and black to ground. - - - Updated - - - In the cable harness was a female radio antenna plug. I have no idea what it is used for, there was nothing plugged into it. - - - Updated - - - In the process of removing the old radio, I disconnected some plugs, which I didn't realize. So I was left with a couple plugs which I didn't know what they are. It is a black wire plugged into a green wire. A black wire on a connector means a ground connection to me. But while this was disconnected, the car would not engage in forward or reverse. The shifter buttons would just flash. Scared the hell outta me! I reconnected it, testing the voltage and current, and it started working again. I don't know why this is bundled in with the radio harness.
So the only difference between the Alpine's connection to its camera and any other is the power supply? That's good to know. I've been tempted to replace my Alpine unit but didn't want to replace the camera, which I thought was proprietary. Thanks for posting this info.
I slapped together this little drawing of what I threw together. No Warranty, use at your own risk The camera image seems noisier or grainy. I don't know if it is because the unclean signal, or the KenWood is a more sensitive display. John's writeup was great, I wouldn't have even tried doing this without his post. But I want to post some 'additional' things I discovered along the way. Hopefully this weekend I can write some thing up. Or send me a private message, and I'll tell you some of the things I had to deal with. -Scotty
Anyone try or think about trying to install the Alpine INE-W927HD to replace the crap Alpine stock unit?
I took a quick look at it. I was told it was designed for SUVs and needed a larger mount which wouldn't fit in the Roadster double DIN. I went with the 920HD instead and am relatively happy with it.
It fits: Works better than the IVA-NAV-10 overall. However, the "camera" button isn't enabled on MyFavorite screen, yet the camera works fine when I go into reverse. Is there some setting I have wrong? Finally, if someone wants a complete set of manuals, warranty cards, etc. for the IVA-NAV-10, let me know - they're yours free if you pick them up from me in Sunnyvale, CA.
Nice! It looks like a bigger version of the 920HD. The camera doesn't appear in My Favourites either - only in reverse.
There are so many settings on this thing to customize the sound. The micro-timing per speaker, for instance. Any ideas how to go about getting it setup best? I played with the main settings and picked what sounded good for a couple different sources, but I'm sure someone who knows what they're doing would do a better job.
I measured the distance from the driver's seat headrest to each speaker to calculate the millisecond offsets. Hard to say if it's better or not when the top's down!
