OK so I pulled the Alpine out yesterday to check the connectors. The 16 pin plug for power and speakers looked similar to the Pioneer, but unfortunately not similar enough.
Anyway, my car and I presume others in Europe are fitted with the Alpine IVA-W502R. This seems to have some important differences to the IVA-NAV-10.
The Nav and Bluetooth are off-board and connected through some proprietary multi-pin bus cables. Eventually these are going to have to be removed.
The reversing camera is connected through a white aux AV connector but only two pins are used and according to the manual I downloaded on the Alpine adapter this just goes to a yellow RCA, so I presume that it does not need the power supply described up thread (or that is somewhere in the wiring loom already).
I didn't see any RCAs or other leads going to speakers, so I presume that any power amp or the sub-woofer is fed from the normal speaker outputs of the Alpine. This would make sense as when I move the fader to the rear it loses the sub.
Anyway, it seems if I can get a female Alpine adapter, I can do a quick and dirty switch to check the Pioneer is working ok.
Link to the manual - installation and wiring details at the back:
https://www.alpine-europe.com/filea...r_audio_manuals/IVA-W502R/OM_IVA-W502R_EN.pdf
Model details
Pin out
Head unit removed
Camera interface unit behind passenger side glove box
Bluetooth unit on driver's side. Note the navigation receiver is in the top right of the picture, on top of the switchpack
Main 16 pin power and speaker connector (hard wired with totally non-standard wire colours)
Camera connector
iPod / USB connector
Nav connector
