boyb1917
New Member
ThanksIf your car is rooted you should be able to do it & if not 3rd party shops can do it
Hi, I own a 2012 Model S Signature P85 and having the same issue with the battery as you did, it failed at needs to be replaced. I wonder if you could share with me how to redeploy the software. I have a module that allows me to switch the car to Dev or Factory mode / redeploy the existing version of the software. Do you think this is all that is required to do the swap? ThanksIf your car is rooted you should be able to do it & if not 3rd party shops can do it
If both batteries or the same revision I think redeploying the software should work if not it might need a config change.Hi, I own a 2012 Model S Signature P85 and having the same issue with the battery as you did, it failed at needs to be replaced. I wonder if you could share with me how to redeploy the software. I have a module that allows me to switch the car to Dev or Factory mode / redeploy the existing version of the software. Do you think this is all that is required to do the swap? Thanks
do you know if a config change is doable in Dev mode or requires additional equipment to be involved? ThanksIf both batteries or the same revision I think redeploying the software should work if not it might need a config change.
I didn't remember where it is but you should be having the option to redeploy firmware in one of the screens if you are in Dev Mode
I am going to try a battery swap myself as well! I found a company in Northern CA that is a tesla automotive dismantle company. They are called Doughnut auto parts. The people are great and helpfull. They have access to perform battery swaps. Now to start the process and check out the battery. I am not sure yet how to integrate the pack with the software. Any tips would be greatly appreciated!I did the battery swap myself with my cousin helping me & one of my friends guided me in pairing the battery to the car.
Overall it is not a bad project as long as you have access to a lift or have multiple sets of jack stands.
Tesla SC uses specialized alignment rods to make sure the battery is aligned properly as I don't have access to them I used 12" screws from Homedepot to make sure the battery is aligned when installing the new pack
If you have any questions please feel free to IM me
Hold down the model number in the software menus and type service to enter service mode. From there can ECU redeploy.If both batteries or the same revision I think redeploying the software should work if not it might need a config change.
Awesome will try this!Hold down the model number in the software menus and type service to enter service mode. From there can ECU redeploy.
LOL that is awesome! I know that @wk057 can help you with the firmware and config portion of your journey!Really cool thread! Congrats on coming out on top and not giving up @goodbadboys9! I just finished swapping 16 Gen 2 modules into a 2013 Model S P85. I need help with the firmware deploy and config portion.
Willing to pay for consult if that’s what it will take, I can’t DM but happy to work with someone who has the solution for me. @JeffreyHowell happy to share any insight, we can also go halfsies on a master tech
If WK057 cant help contact donut auto in NorCal. He can steer you in the right direction. He has a sister shop that might be able to help as well.LOL that is awesome! I know that @wk057 can help you with the firmware and config portion of your journey!
wk057 replied to u in salvage owners thread about this but for everyone else who reads this, BMS/BMBs need to match.Really cool thread! Congrats on coming out on top and not giving up @goodbadboys9! I just finished swapping 16 Gen 2 modules into a 2013 Model S P85. I need help with the firmware deploy and config portion.
That is correct I spoke to Russ at 057. He was nice and very pleasant. Unfortunately I’m in California. So that made it a non starter.wk057 replied to u in salvage owners thread about this but for everyone else who reads this, BMS/BMBs need to match.
I appreciate the referrals my friend!If WK057 cant help contact donut auto in NorCal. He can steer you in the right direction. He has a sister shop that might be able to help as well.
It might be a good idea to join the Facebook page called BMS_u029/BMS_u018. There is a lot of talent there including Recell. Ask the question and I'm sure you will get some good answersI appreciate the referrals my friend!
