Good work. Several stories have claimed the LEAF was top of the flops last year. Your post shows it was nowhere near.
Strongly disagree with this. Yes the Volt is seen as an EV, even though it is not, and as such it is seen as an over priced 40 mile range "EV", and all the negative press it has garnered has been used to paint EV's in a negative light. The Volt is a hybrid, by common and legal definition, and so should be lumped in with other hybrids. If the Volt had been marketed as the hybrid it really is from the beginning EV's as a whole would have gotten much less negative press. The Volt has not been a net gain for the EV movement and has in fact been the lightning rod for the anti-EV crowd to focus on.Sales of the Volt are helpful to the EV cause no matter that the car is a PHEV as the perception is that it is an EV.
.... When a person approached me at a local auto show to brag that he bought a Leaf, drove it and ran out of juice so proudly returned the car to the dealership (that's a whole other tangent) it came out that he did not charge it every night but yet did charge his cell phone every night, that hurts the EV community as well....
Strongly disagree with this. ...
So the Volt is both good and bad for EV's? Which makes it neutral? I'm confused.
None of the politicians, that I know about.Are there any democrats spreading anti-EV FUD?
Interesting. The only "shifting emissions" comments I've had in person were from obvious GOP faithful.
The easy rebuttal to the "long tailpipe" (aka "shifting emissions") argument is to note that refining a gallon of gasoline takes about 6kWh of electricity -- enough power to drive a Tesla about 20 miles. Once you put that power into the balance, EVs clearly come out ahead, particularly when you consider the heavy reliance on coal to generate power in Gulf Coast states, where a lot of US refineries are located.
There is a factual problem with this however. I believe that there is around 6kWh of energy used to refine a gallon of gasoline but only a small part of that is actually in the form of electricity, and grid purchased electricity is an even smaller part yet. I think in general conversation it's better to use the word energy if using the 6kWh figure, most people won't notice the difference and if you are challenged you are technically using correct terminology and can then specify that a portion of that is electricity from the grid as well as electricity generated on site.The easy rebuttal to the "long tailpipe" (aka "shifting emissions") argument is to note that refining a gallon of gasoline takes about 6kWh of electricity -- enough power to drive a Tesla about 20 miles.
