Reseal HV Battery?
Zuikkis
185
226
Finland
Hi!
My 2013 P85+ is going to SC this week for MCU daugherboard replacement. I wondered when they initially said it will take four days! But now I see on the service agreement that there is a lot of stuff being done to HV battery:
This was not explained to me, at least not yet. I'm going to ask when I leave the car there. Anyone else know what's going on?
Is it possible they have noticed some issue remotely, or is this some kind of a recall? I have 11 months left on the 8 year battery warranty, maybe they are trying to remedy something just enough so it lasts one more year before complete failure? :)
Reactions: SmartElectric
Brass Guy
1,140
930
Holbrook, MA
I was told it's a service bulletin. I brought mine in about a week ago with a "Battery charge limit will be restricted" error. They ordered the same parts for mine too, which seems like a waste if it's likely I'll be getting a battery swap because of this message.
Zuikkis
185
226
Finland
Ok thanks.
I haven't got any errors on display, but I don't know if they have noticed something remotely.
"Reseal" sounds like there maybe is a potential way for water to get in, which they now are fixing? Also the Mudflaps in part listing seem to be very new part, the part numbers are not found in Tesla EPC.
Zuikkis
185
226
Finland
They said it's an change in battery design which should improve battery life expectancy. So probably a good thing. Unless if it makes my battery last just so little longer that it's no longer under warranty when it fails. :)
Brass Guy
1,140
930
Holbrook, MA
Well that's the big "if." Mine is 7 years and 2 months old, and from what I've read on this forum about my error message and symptoms it looks like my battery may need replacing/repair. I did not install the infamous software update (that reduced range in many 85 cars and increased supercharger times in probably all of them - supposedly in the name of battery longevity) because of the terrible changes in the interface. If I do get a replacement battery, I will always wonder if the software update would've pushed the problem out another 10 months and past the warranty.
JohnQ
1,612
75
Redding, CT
Might have, might not have. I have an April 13 and had the battery replaced about a month ago under warranty. Have kept software/firmware up-to-date. Hope you get a good pack!
Lewis88
22
The Netherlands
Same thing for my car, they told me there's an open service item on the HV battery which will take a whole day, going to bring in in next tuesday. Did you get a new battery or not?
Brass Guy
1,140
930
Holbrook, MA
So far they've only updated my firmware. I was told the tech wanted some drive cycles now that the car's updated. (They kept the car 2 1/2 weeks!)
The app works again, I hate the new interface, and the app says 100% is 212 miles. It was around 240 before an error message came up 4 weeks ago.
They did not do the battery re-seal yet either, they want it back in a month.
Lewis88
22
The Netherlands
Ok, so brought it in today for the re-seal. It's not about the seal, its about checking coolant connections within the HV battery. They need to pop the top and check the connections, replace some parts, and reseal.
I got a really snappy P90D as a loaner, which is nice. Currently waiting on the result. The nominal charge of my 85 dropped from 76 to 70kWh this year, so hopefully my pack is full of coolant. But I bet it's just fine and I'll just get it back the same way.
Lasttoy
1,566
834
St Augustine, Fl
I got a total battery pack replacement last week. My bill had only 3 lines, new pack, new coolant, new cover part. My pack was still under warranty. Wow, I'm lost as to why your car needed all that work, glad it was done though. They changed my pack in one day.
Lewis88
22
The Netherlands
Just got the car back, dont notice anything different. They had to order and replace the rapid mate plate as well, basically the male connector that sticks out of the car into the battery, due to corrosion. So obviously there was water intrusion.
They also were suprised my P90D loaner wasn't locked into chill-mode. Lucky me. They believe is was "hacked". Ha ha ha...
Anyway, I'm happy. Still wondering wether or not the car had logged a fault I couldn't see.
Chris8888
New Member
Dec 1, 2020
FISHKILL, Ny 12524
So i just brought my 2015 P85 in for the battery re seal and a problem with one of my fobs.
As they were going to return the car, they stated that the high voltage charger was no good and I had to replace it at a charge of $ 3000.
There were no problems charging prior to my appointment and they are stating that the battery re seal has nothing to do with the high voltage charge. It will charge at home,, but not a supercharger. There must be a correlation with their work and my new problem.
Reactions: aerodyne
Electric700
1,695
358
Florida, United States
Welcome to the forum! You should explain that Supercharging was working before you brought it to Tesla. They can check your car's logs.
