Research claims battery-electric cars are greener than expected
Discussion in 'Energy, Environment, and Policy' started by mpt, Sep 7, 2010.
  1. mpt
    mpt Electrics are back
    Warren, New Jersey, United States
    Source IET
    http://kn.theiet.org/news/aug10/e-car-lca.cfm
  2. Jaff
    Jaff Active Member
    Grimsby, Canada
    A good article...nice to see some current comparative information!
    I guesss the Pertol-Heads know where they can stick their "long-tailpipe" arguments...:tongue::biggrin::wink:
  3. dpeilow
    dpeilow Moderator
    Winchester, UK
  4. kgb
    kgb Member
    Houston, TX
  5. Brent
    Brent Member
    Los Angeles, CA
    Aren't the reports making the same claim? That is, they both seem to be saying that the greeness of electric cars depends largely on how the electricity is generated, and that batteries don't factor much into the equation.
  6. mpt
    Brent, I followed the link to the original article at http://pubs.acs.org/doi/full/10.1021/es903729a
    So, yes, I think they're in agreement.
    As far as I can tell the research was carried out on a petrol gasoline car rather than Diesel so I think, all bets are off wrt the diesel headline.
  7. eledille
    eledille TMS 85 owner :)
    Oslo, Norway
    #7 eledille, Sep 8, 2010
    Yes, they are. The numbers are peculiarly similar.
    The Register chooses to read the report as negative for electric cars, while it is in fact very positive.
    For a diesel car to have any chance of beating an electric, it will have to be small, underpowered, and never be even close to a traffic jam. No cold starts, please. Also, the electric car must get its power from "european mix", which includes a lot of coal.
    They also assume that heating/cooling/electronic devices consume 17% of the battery capacity, a whopping 2.9kWh/100km. Electronic devices can safely be ignored, so they assume resistive heating. Switching to a heat pump would immediately blow the ICE away.
  8. eledille
    Oslo, Norway
    #8 eledille, Sep 8, 2010
    They state that to achieve break-even with an electric car charged with european power mix, an ICE would need to consume 3.9 liters of fuel of unspecified type per 100km according to one life cycle impact assessment method (CED), or 2.6 liters according to another (EI99 H/A). Then they point out that consumption in this range is achieved by some small diesel cars. What they don't mention is that real-life fuel consumption will always be higher than this unless you live in the countryside and always use an engine block heater in the winter.
  9. stopcrazypp
    stopcrazypp Well-Known Member
    #9 stopcrazypp, Sep 8, 2010
    That's not the main problem. The main problem is the diesel fans always like to use their MOST efficient diesel cars to compare to the baseline average of different technologies. They do the same to hybrids. They always bring up a car like the Polo to compare to the Prius, when the Prius is both significantly larger and more powerful. It isn't a fair comparison unless they compare similar cars.
